Premiere Pro 2 motion problem
I have a problem with motion plugin in premiere pro 2.
I have a project with the dimensions of 2405×1300 pixels. I use still image (Tiff) sequences in it. The sequences are 2464×1648. Now I want to move one of the clips a little bit up, becaus I have around 200 pixels left on the side anyway. But when I use Premiere Pro’s motion plugin for that there is a problem. In the preview screen (in premiere) it looks all ok. But as soon as I export it as a Tiff or as any avi file, there appears a black bar on the bottom (I moved the sequence a little up). So instead of using the rest of the pictures below it (as I want it) it just cut it off and than move it up. Is there a way to avoid this and get premiere to render the lower part of the image as well?thank you very much for you time.
