Activity › Forums › Adobe Premiere Pro › Premiere Pro 1/5 running in XPMode lost its sound drivers.
Wallace Adrian d’alessio replied 14 years, 4 months ago 3 Members · 24 Replies
March 28, 2012 at 3:31 amAs my deceased brother used to say “It’s better than the one I haven’t got !”
My own freelancing can go on now. This will work just fine for local website inserts. And give me control Movie maker will never have. SD is still acceptable for most low end work. And I can serve a local market otherwise priced out of modern imaging and small production.
If I can earn a little money then I can buy better. And I can still cut some HD with Win 7 Movie maker. Or get a Pinnacle version.
PP 1.5 in XPMode is working better and faster than on many of the Celeron and Pentium setups I have run it on in the past. The i3 and bigger RAM allocation have done magic. And will get better when I add RAM and allocate even more free RAM to PP 1.5 .
Thank you Bob, for your interest and encouragement.
Adrian D’Alessio aka; Fluxstringer
fluxstringer@gmail.com
https://www.facebook.com/FluxStringer
https://www.linkedin.com/in/fluxstreamcommunications
https://flux-influx.blogspot.com/
https://fluxdreams.designbinder.com/
https://twitter.com/FluxStringer
https://mog.com/FluxMuse -
Bob Dix
March 28, 2012 at 4:30 amThank you Adrian,
Yes SD is till used here too, things are changing fast though. Don’t forget the Windows limit of 4GB on 32 bit software, so increasing it in PP 1.5 may not help much if at all, but, will be of assistance when you use a 64 bit application.
Good luck
Freelance Imaging & Video
AUSTRALIA -
April 20, 2012 at 4:05 pmI started having some trouble again when I was trying to get AE going.
Again no sound.
Also was trying to set up scratch disks for PP and AE. So I had to set up virtual disks on a SATA external with 7200 RPM to held render palyback over the slower system drive.
I firmly believe Microsoft engineers write with the maxim of giving systems the most chances to fail and hiding the controls from the user.
Anyway after reading the misleading and inaccurate info several times I found yet another virtual machine XPmode control panel I found shared audio resources on startup unchecked even though it had worked before and even though PP was playing audio !
April 20, 2012 at 6:11 pmNow it is broken again. I must conclude that Microsoft Windows constant insistence on updates,verifications and additional”services’, and checks are intentionally meantto break the system you have working so you will gain incentive to just buy new software form it’s partners or from microsoft. Their market approach and red supposed concern and respect for user needs are pure bool-S h i t !
