Activity › Forums › Adobe Premiere Pro › Premiere Pro 1.5 & Magic bullet editors compatibility issue??
  • Premiere Pro 1.5 & Magic bullet editors compatibility issue??
    Posted by Jinro1 on December 10, 2006 at 2:30 pm
    Im running adobe premiere pro 1.5 with canopus dvstorm card. Everytime i open up premiere it crashes when i have the magic bullet editors plug in installed. Need suggestions to fix this issue. thanks.
    Tim Kolb replied 19 years, 9 months ago 2 Members · 1 Reply
  • Tim Kolb
    December 10, 2006 at 3:25 pm
    Did it ever work for you, or are you first trying to install Magic Bullet Editors now? Be aware that the newest version of MBE is designed for the plugin structure of PPro v2, which is different than v1.5. Perhaps you could describe your situation in detail and there might be some answer…but:
    I never tried using them all together as I had to make a choice between PPro and a big machine and DV Storm when I had runnability issues early on…I ended up just getting a bigger machine to edit DV and dropping the card.
    …since the DV Storm card is no longer produced and PPro almost famously had issues with it for most, there is going to be no effort to patch or fix this combo (if it is a legitimate conflict) by the software/hardware manufacturers concerned.
    I’d say you might be stuck with an issue that can only be resolved by giving up one or the other…and upgrading PPro to the current version if you have the current version of MBE.
    Sorry i don’t have anything more specific without more detail.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
