Premiere preview window
Hi
I have a little problem with the preview window in Premiere. It then expands very, That one can not even run single frames Profile. When I press play, Bleibts simple as frozen. In Vegas could be quality and adjust window size, That helped. In Premiere Is that also, Tuts but no help. 4gb RAM and a quad core should be well enough to play the semi-liquid preview. Without the editing window, it is impossible to.
Thank you in advance
