Activity Forums Adobe Premiere Pro Premiere – Not able to move clips up/down w/ keyboard
  • Premiere – Not able to move clips up/down w/ keyboard
    Posted by Adam Eyster on May 19, 2014 at 11:12 pm
    Hi all,
    Trying to figure out a resolve for an issue I’m having in Premiere.
    I would like to play a clip and set in/out points along the way.
    The problem is, when I do this, it does NOT highlight the clip in the timeline. I want to be able to use the keyboard, select the part of the clip within the in/out points, and move it up/down between tracks.
    No keyboard shortcuts can be found for Nudge UP or DOWN in my Premiere Keyboard Shortcuts as well.
    NOTE: i’ve seen this question posted before, no answer really achieved yet. Hoping someone can figure this out!
    Tim Kolb replied 12 years, 4 months ago 3 Members · 3 Replies
  • Tim Kolb
    May 20, 2014 at 1:34 pm
    If you aren’t using CC, there isn’t a way to move clips up and down.
    If you are using CC, then it’s Alt (Opt)+cursor up/down
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Kevin Monahan
    May 21, 2014 at 4:05 pm
    Yes, Tim. Also, if you’re using “Final Cut Pro” shortcuts in CC, nudge clip selection up/down does need to be set manually.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Tim Kolb
    May 23, 2014 at 7:31 pm
    [Kevin Monahan] “Yes, Tim. Also, if you’re using “Final Cut Pro” shortcuts in CC, nudge clip selection up/down does need to be set manually.”
    Oh yes, the FCP shortcuts…why would someone use those again? 🙂
    TimK,
    Kolb Productions,
