Activity Forums Adobe Premiere Pro Premiere Newb – Why Can’t I Razor-Cut a Single Frame of Video?
  • Premiere Newb – Why Can’t I Razor-Cut a Single Frame of Video?
    Posted by Bill Henderson on August 25, 2017 at 3:40 pm
    Hi – I’m trying to duplicate the process described in this YouTube video for taking a single frame and stretching it out as needed:
    https://www.youtube.com/watch?v=vYf-JTMgxTA
    However after I make the first cut, zoomed all the way in, I cannot make another cut either before or after my first cut. No errors, just no razor cut. Just sits there doing nothing. Actually I’ve zoomed out and tried a cut ANYWHERE on this clip after the first razor cut and I can’t cut anything. I’ve shut down the project and Premiere because sometimes it just glitches, but that’s not what is happening here either. Not sure it matters but two video clips of different frame rates in the same project are exhibiting this problem. The first cut is fine, but a second cut is impossible.
    Is this some basic setting I clicked on perhaps? Any other ideas?
    Bill
    Bret Hampton replied 8 years, 12 months ago 2 Members · 4 Replies
  • Bill Henderson
    August 25, 2017 at 6:51 pm
    Well FYI – if I start from a brand new project and import a fresh clip, it’s working fine. I was hoping to use my existing project since I’d spent hours editing other pieces, but since I’ve just spent hours failing to do this basic thing, I’m tempted to just keep going on my new project.
  • Bret Hampton
    September 6, 2017 at 9:11 pm
    Bill
    That’s an odd one. Only thing I can think of is you’re editing clips with Long GOP structures. Those can be 15 frames and you can’t cut within that range. These are used in DVD/Blu-ray compression. Check your sequence settings and file types.
    Also try the same thing with a Color Matte. Make a matte, put in timeline and stretch out to several seconds. Razor cut within that. If it works that points to a file issue. If it doesn’t work maybe sequence settings.
  • Bill Henderson
    September 6, 2017 at 9:22 pm
    Thanks Brett – yes I believe it was sequence settings. I’d been playing around with Blu-Ray output. It hasn’t happened again.
  • Bret Hampton
    September 6, 2017 at 9:33 pm
    That’s good
