Activity Forums Adobe Premiere Pro Premiere MPEG2 Exports are “Purple”
  • Premiere MPEG2 Exports are “Purple”
    Posted by James Orlowski on November 7, 2006 at 12:54 am
    Any idea why my MPEG2 exports turn out as if there were a purple filter over top? Other export types (like WMV) work fine.
    I’ve tried several MPEG2 settings, including the default Premiere settings, and they all turn out the same. Purple.
    I have a BOXX Workstation running Premiere Pro 2.0 with an AJA Xena HS card.
    Thanks.
    James Orlowski
    RYNO Production, Inc.
    http://www.rynoproduction.com
    800-860-7066
    James Orlowski replied 19 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Aanarav Sareen
    November 7, 2006 at 4:14 am
    Can you post a screenshot of the exported MPEG2 output? Are you using any filters on the video?
    Aanarav Sareen
    premiere@asvideoproductions.com
  • Mike Smith
    November 7, 2006 at 10:49 am
    Needless to say, this is not “normal”. You’re not running a trial version of an mpeg2 codec?
  • James Orlowski
    November 7, 2006 at 6:29 pm
    I’ll do one better…
    Here’s an actual MPEG2 output example of my problem. Looks like the chroma is off for some reason.
    https://www.rynocable.com/misc/Sample.mpg
  • Vince Becquiot
    November 7, 2006 at 7:12 pm
    Looks fine over here bud. Looks like a player issue.
    Vince
  • James Orlowski
    November 7, 2006 at 7:37 pm
    Yea, it looks like my Media Player is playing only MPEG2 files purple. All other media types are ok.
    I’m not going to worry about it.
  • Vince Becquiot
    November 7, 2006 at 8:11 pm
    You could try upgrading to version 11.
    Vince
  • James Orlowski
    November 8, 2006 at 4:58 pm
    I got my issue worked out:
    It was a setting in my WMP10 player. I turned off “use overlays” in the Tools… Performance… Advanced… tab.
    Don’t know what it does or why my MPEG2 files play “purple” when it’s on, but I found the workaround.
