Activity Forums Adobe Premiere Pro Premiere Markers to After Effects
  • Premiere Markers to After Effects
    Posted by Doug Zaner on June 20, 2012 at 12:23 am
    Hello,
    Is there a way to create a sequence marker in Premiere Pro 6 that will travel to After Effects? I have left room in my edit for animation and would like to bring the sequence into AE via dynamic link and see the markers in the comp. One of my clips has a marker in it and that source clip marker has traveled to AE but not the sequence markers.
    Thanks much
    Doug Zaner replied 14 years, 3 months ago 2 Members · 2 Replies
  • Alex Udell
    June 20, 2012 at 2:10 pm
    Not sure….
    but as a workaround….could you drop a video clip into your sequence and mark it up according to the timeline markers?
    then just mute in AE, but you’d still get the markers….
    Alex
  • Doug Zaner
    June 27, 2012 at 12:21 am
    Hi Alex,
    So sorry for the delayed reply. I gave it a shot but no luck. The sequence markers will travel but if I make a change in Premiere, reload in AE won’t update the markers. I tried using pro import as well but there isn’t anyway to update the sequence markers. The best solution I found was just to delete the dynamically linked sequence and re-import.
    Thanks for the reply, sorry again for the delay.
    Doug
