Activity Forums Adobe Premiere Pro Premiere interpreting wrong frame rate when logging footage in cs5.5
  • Premiere interpreting wrong frame rate when logging footage in cs5.5
    Posted by Jelani Johnson on February 1, 2013 at 11:21 am
    I am logging footage for a wedding from a canon xh-a1(still using tape), I shot the footage in 24 frames. At first everything was working perfectly. I logged the footage and the frame was being interpreted correctly(23.97) Then all of a sudden it changed my interpreted frame rate to 29.97, and now when I go to batch capture it tells me capture failed I can’t find my in point. I would like to know how to fix this problem, but for now I need to know how to change the interpreted frame rate of these offline files that won’t capture.
    Chris Tompkins replied 13 years, 7 months ago 2 Members · 1 Reply
  • Chris Tompkins
    February 1, 2013 at 3:37 pm
    I thing when shooting on tape with that camera the 24p is inside a 29.97 stream. Your edit should perform the pull down.
    Chris
