Activity Forums Adobe Premiere Pro Premiere Exports Empty File
  • Premiere Exports Empty File
    Posted by Zoltán Király on April 11, 2014 at 2:03 pm
    Hi!
    I’m trying to export my project from Premiere CS6. I’m using Windows 7. The file I’m getting is the right size, but doesn’t play back in my video player (I use VLC and the codecs that came with it, nothing on top of that is installed.) When I try to play the file, it shows up as if it had 0 length.
    This sometimes happened before, but changing the drive to which I output my video used to solve the problem. Not anymore, no matter which drive I export to I get the same problem. (I have ample space on my drive, 10GB space for a 3GB file.)
    My output format is 720/23.976p h264 with an mp4 containter and 15/30 VBR 1-pass compression.
    The sequence I’m exporting has a number of other sequences in it, along with other footage. All the other sequences export normally.
    Somebody please help me solve this mystery.
    K.Z.
    Zoltán Király replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
