Activity Forums Adobe Premiere Pro Premiere Exporting Multiple Files
  • Premiere Exporting Multiple Files
    Posted by Editor Arnold on March 10, 2006 at 1:43 pm
    Im editing on PP1.5 and need to export multiple files (sequences). into avi formats. They are interviews and each clip is a sequence -there are roughly 30+ sequences for each of the 37 interviews. Yes…..a lot of footage! Is there a plug in, or we are getting PP2 very soon will i be able to do multiple exports in that? finally is there a way to export all the sequences to AFX then do it that way?
    Ive read all the threads on this site, which are helpful but dont really give a indepth answer
    Many thanks
    Aanarav Sareen replied 20 years, 6 months ago 3 Members · 3 Replies
  • Aanarav Sareen
    March 11, 2006 at 6:26 pm
    1. You cannot batch export from Premiere Pro
    2. You can import a Premiere project in AE, but you will you loose a few transitions.
  • Rob Mack
    March 14, 2006 at 8:04 pm
    This is not good. Is there any other way to set up a render queue for Premiere projects? Can Cleaner do it, or is Premiere scriptable in any way?
    Rob Mack
  • Aanarav Sareen
    March 21, 2006 at 1:35 am
    [rob mack] “Is there any other way to set up a render queue for Premiere projects?”
    Not really. Unless, you have After Effects, then it is possible, but it will take After EFfects a lot more time.
