Activity Forums Blackmagic Design Premiere CS6,Only single fieled is played to external monitor
  • Premiere CS6,Only single fieled is played to external monitor
    Posted by Masashi Sato on November 2, 2012 at 7:52 am
    Hi, I tested PremiereCS6 with Decklink SDI.
    Premiere can’t play correctly the interlace Sequence ,via Decklink ,in GPU mercury engine mode.
    Only single fieled is played to external monitor via Decklink.
    I upload the test video.
    https://dl.dropbox.com/u/5542662/interlace-test.mov
    (16MB, clip)
    Please,playback test.
    When you play the video via deckling to external monitor in GPU mercury engine mode,
    Are there 2 flashing square?
    If you play the video correctly, there are 2 flashing square.
    If you see no square or 2 white square, Premiere play a only field of the video.
    Decklink support PremiereCS6 in only software mercury engine mode?
    Masashi Sato replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
