Activity › Forums › Adobe Premiere Pro › Premiere CS6 – Broken Media Export
  • Premiere CS6 – Broken Media Export
    Posted by Ashley Hartzell on March 21, 2013 at 8:12 pm
    I recently installed CS6 Creative Cloud and am hoping to export a video from Premiere. However, after setting in/outs and choosing to Export Media (default settings) I’m receiving the following error message:
    I believe I may need to uninstall and reinstall. However, has anyone received this message in the past? Does anyone have a work-around? I can provide any information you need to assess the issue. I receive the error when attempting to export any length of video, any type of video, any audio files etc. I’ve tried to export through Encoder and that fails as well.
    Your assistance is greatly appreciated. Thank you!!
    Dan Mcmahon replied 13 years, 6 months ago 4 Members · 4 Replies
  • Chris Tompkins
    March 21, 2013 at 9:14 pm
    Are you “sending to queue”?
    Chris
  • Chris Walsh
    March 21, 2013 at 10:26 pm
    I got the same error this morning. Encoded nearly entire sequence, then stalled and gave the error. Have not found a workaround yet (ended up recutting in FCP7), am going to play around with prefs etc. now that I’ve delivered. What’s your setup?
    I’m running CS6.0.2 (creative cloud sub) on a Mac Pro (OS 10.6.8).
    Chris Walsh
    http://www.musicfog.com
    Silver Spring, MD
    Final Cut & AVID MC5
    Former Windows User and edit* lover
  • Chris Walsh
    March 21, 2013 at 10:46 pm
    Repaired permissions on my boot drive using Disk Utility, restarted, and now the same project exports without a hiccup.
    Chris Walsh
    Silver Spring, MD
  • Dan Mcmahon
    March 22, 2013 at 6:54 pm
    I had this problem once, and if you export to your desktop it worked, not sure why, but it worked
