Activity › Forums › Adobe Premiere Pro › Premiere CS5.5 won’t work with Sytem Default Input/audio
  • Premiere CS5.5 won’t work with Sytem Default Input/audio
    Posted by Tielman Dewaele on February 12, 2012 at 6:29 pm
    hey,
    i while a go i updated my intensity pro card for it use with Premiere(i used it for years on FCP). After using the card on PP, suddenly premiere would work. The time indicator wont work when pressing play or l.
    I thought it would be because of the card, so i removed the software from BlackMagic. After uninstalling the same problem a cured.
    Then i discovered premiere wont do anything when the audio hardware is set to “System Default Input/Ouput”. Setting it to something else premiere does work, but i have no sound.
    Luckily i have cs5 still on the computer and i am editing my stuff on there for the moment. This problem does not appear in cs5.
    Any one had this problem? Something similar.
    Please help me out.
    T
    MacPro Intel Quad Core 17G Ram
    MacBookPro Intel Duo Core 2G Ram
    Cs5 Production Premium
    Cinema4D 11.5
    Final Cut Studio 2
    Kevin Monahan replied 14 years, 7 months ago 2 Members · 1 Reply
