Activity Forums Adobe Premiere Pro Premiere CS5.5 Autosave and Save creates unwanted key frame value changes.
  • Premiere CS5.5 Autosave and Save creates unwanted key frame value changes.
    Posted by Ciro Coleman on April 25, 2019 at 1:15 am
    Hello Peeps,
    Any answers to the following problem, please?
    I recently reformatted my Laptop and reinstalled a fresh copy of Windows 7 64bit from the hard drive. I then installed Adobe Premiere CS5.5 and started to edit my videos. I didn’t realise until watching a rendered piece of footage that the Scaling and Position were all wrong.
    I discovered purely by chance that the Autosave and Save functions were changing the keyframe values. To get around this, I now complete editing my videos without adding any Scaling or Position keyframes, save the project then deselect the Autosave function before starting to do all the Scaling and Position changes that I want.
    Although it’s a work around it’s a pain in the backside and I’d rather do all the necessary changes as I edit the video plus this shouldn’t be happening, right??
    Does anyone have an answer? A proper fix to this problem if you’ve encountered the same??
    Thanks in advance
    Ciro
    Ciro Coleman replied 7 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
