Activity Forums Adobe Premiere Pro Premiere CS5 – Trouble recording audio
  • Premiere CS5 – Trouble recording audio
    Posted by Kevin Obrien on July 10, 2013 at 6:35 pm
    I’m using Premiere Pro to record voice-over in a project in the Audio Mixer window. I’m using a Samsung Go Mic (USB)
    When I record an audio track and hit stop most times the audio file shows up in the Project window as a white rectangle with “recycle arrows” as opposed to the “speaker” icon. The recorded audio track is blank. BUT if I shut down Premiere and open it back up the audio file is there and plays normally.
    Suggestions as to whats going on?
    Kevin Obrien replied 13 years, 2 months ago 2 Members · 14 Replies
  • 14 Replies
  • Ericbowen
    July 10, 2013 at 7:48 pm
    Are you recording the file as a wave file? What version or Premiere are you running?
    Eric-ADK
    Tech Manager
  • Kevin Obrien
    July 11, 2013 at 5:09 pm
    Yes… as a WAV file.
    I’m running CS5 Extended
  • Ericbowen
    July 11, 2013 at 8:58 pm
    Do you have the 5.0.3 update?
    Eric-ADK
    Tech Manager
  • Kevin Obrien
    July 11, 2013 at 10:00 pm
    not sure… what’s the quickest way to tell?
  • Ericbowen
    July 11, 2013 at 10:14 pm
    Go under Help in Premiere and select update. Then see if there are updates.
    Eric-ADK
    Tech Manager
  • Kevin Obrien
    July 12, 2013 at 12:41 am
    yes… its up to date
  • Ericbowen
    July 12, 2013 at 12:56 am
    What OS is this on? Are you recording to an internal or external drive?
    Eric-ADK
    Tech Manager
  • Kevin Obrien
    July 12, 2013 at 12:59 am
    Windows 7 I was recording on an external drive (5400rpm)
  • Ericbowen
    July 12, 2013 at 3:29 pm
    What happens if you record to the OS drive?
    Eric-ADK
    Tech Manager
  • Kevin Obrien
    July 12, 2013 at 6:16 pm
    That seems to work… Thanks!!! Any idea why it wouldn’t record to the external 5400rpm drive?
    Also, Eric, do you have any expertise in PC Builds for Video Editing?
