Activity Forums Adobe Premiere Pro Premiere CS5 playback problems
  • Premiere CS5 playback problems
    Posted by David Lavender on June 13, 2011 at 12:32 am
    I’m suddenly having heaps of problems simply getting my footage to play back in my CS5 timeline. I’m not aware that I’ve changed any settings. Clearly this is a user error, but I’ve done fairly extensive searching, and I can’t find the answer to my problem. I’ve been editing in CS5 for months with the same workflow, and the problem is suddenly grinding me to a halt.
    – I shoot with a few Canon 7D cameras.
    – Footage is obviously H264, usually @1080p 23.976
    – I drop the native footage in
    – When I hit spacebar to play in the timeline (also happen in the project window), the play button changes to a stop button, as it normally would, but the video doesn’t play back. After a few seconds of nothing, the stop button changes back to a play button (as if I had stopped the video)
    Any ideas? I’m editing on an iMac with a 2.66 i5 chip and 8GB of RAM. It’s not a beast, but it’s not an underpowered machine, either. Thoughts?
    Jon Barrie replied 15 years, 3 months ago 2 Members · 1 Reply
  • Jon Barrie
    June 14, 2011 at 12:28 pm
    Did you recently unplug the audio out jack? That can cause a similar problem with PPro if it was done while PPro was open. Usually a switch away and back to PPro App can get it to play nice again. Otherwise a reboot will do the trick.
    If you are still getting the problem try to start a new sequence and copy the clips to it. Test. If still happeniing, start a new Project and import the old project into the new one. Test. If still there I would attempt to isolate whether or not it’s just that clip…
    Hmmm.. Let us know if you are still having the issue.
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
