Activity Forums Adobe Premiere Pro Premiere CS4 + DSR-DU1
  • Premiere CS4 + DSR-DU1
    Posted by Martin Werner on March 4, 2010 at 11:15 am
    Hey guys,
    i need your advice/help. 🙂
    I’ve got a Sony DSR-DU1 and want to use it with my Sony DSR570.
    Everything works fine.. except one thing: Getting the data into my NLE (Premiere CS4 running on Windows). I have no problem with real-time capture, but i cant just “drag&drop” the files.
    The only thing i have found by now is a Plugin for use with Premiere 6.5 to enable direct import from the DSR-DU1 – Wich does not work with CS4, certainly.
    Any help appreciated!
    Martin
    Philip Van porten replied 16 years, 5 months ago 3 Members · 4 Replies
  • Philip Van porten
    March 4, 2010 at 3:21 pm
    same problem here with du-1 with dsr-500 on windows. av/c-protocol is no problem, sbp2 doesn’t work. i’m getting a sony device with a call sign in my device manager, but no drive to select.
    trying now to geht some new firmware …
  • Brian Louis
    March 4, 2010 at 11:07 pm
    [Martin Werner] “but i cant just “drag&drop” the files”
    Drag and drop the files where? I thought you could just treat the DU1 as a hard drive and copy files to the computer video storage
  • Martin Werner
    March 5, 2010 at 9:12 am
    @Brian: This is what i meant – Sorry if I wrote it misleading. I can import the video through normal “Capture”. But I dont get access to the files directly on the DU1 – And this is what i need to be able to 🙂
  • Philip Van porten
    March 22, 2010 at 12:16 pm
    SOLVED!
    Win Vista and 7 do have problems with sbp2-protocol over firewire. A solution is provided by using the drivers from Unibrain /(https://www.unibrain.com).
