Premiere CS4 Boris FX 9.3.2 Transitions alpha not working
Ok, so I finally upgraded Borix FX 9 for my new CS4 setup.
I am having an issue that I can’t seem to get rid of.
I use the transitions for Titles (page peel in, and then out)
the title is on V2, the base video is on V1. The title is a photoshop file that has no background.
I select the alpha channel options in Boris. The tranistions works fine, but the alpha channel does not, until the transitions is done, then its fine. so the page peel in is the title on black, then the black disapears, then it comes back on the page roll out.
Is this an issue on how I am setting it up, or does FX9 just not do transitions on V2 and up well? I did use it as a filter and got it to work, but that is Premiere 6.0 junk, (ie having 3 pieces, the in filtered piece, the static piece an the exit piece)
I was hoping to not have to do that kind of stuff. : ]
Also what happened to the PARTICLES!!! FX 6 had a great set of particle transitions that i used, now they seem to have moved and some are removed. (lame!)
