Activity Forums Adobe Premiere Pro Premiere CS3 + Decklink SP: No external Monitor
  • Premiere CS3 + Decklink SP: No external Monitor
    Posted by Guenter Sauernheimer on July 29, 2009 at 4:56 pm
    On WindowsXP Prof. i installed Premiere CS3 and Decklink SP with actual drivers and versions. There was no problem during installation.
    Under widows the extendet monitor(YUV)on Decklink is running perfect.
    Also audio and capturing in Premiere by setting to balckmagic is running.
    My Problem is, that the videooutput for the second monitor in Premiere can not be routed to Decklink. There is no setting in Premiere-> Project-> Project properties->general->playout properties.
    The dropdown listbox external device has no item for decklink. But in properties for audio and capturing the blackmagic ist available.
    I am totaly desperate. Can anyone halp me?
    Guenter
    Guenter Sauernheimer replied 17 years, 1 month ago 2 Members · 4 Replies
  • Brian Louis
    July 29, 2009 at 5:14 pm
    [Guenter Sauernheimer] “Under widows the extendet monitor(YUV)on Decklink is running perfect”
    [Guenter Sauernheimer] “My Problem is, that the videooutput for the second monitor in Premiere can not be routed to Decklink. There is no setting in Premiere-> Project-> Project properties->general->playout properties.”
    How many monitors are you trying to run?? two computer monitors plus a external video?? or one computer + external video??
  • Guenter Sauernheimer
    July 29, 2009 at 5:18 pm
    It’s only one external monitor over Decklink.
  • Brian Louis
    July 29, 2009 at 5:31 pm
    The reason I asked how many monitors you are using and for what is that it appears you are extending your desktop on to a external video monitor
    <>Under widows the extendet monitor(YUV)on Decklink is running perfect.<>
    July 29, 2009 at 5:46 pm
    Hi Brian,
    what i want is, using the player of permiere on my pc monitor and show at the same time the full screen on external monitor (YUV). This output goes to a video mixer and will be mixed life with 2 cameras to a video wall.
    Why the decklink-card can not be found in the Premiere dropdownlistbox of external monitors?
