Activity › Forums › Adobe Premiere Pro › Premiere CS 5.5 is having a hard time importing MXF files spanned across three P2 cards.
  • Premiere CS 5.5 is having a hard time importing MXF files spanned across three P2 cards.
    Posted by David Tannenbaum on June 14, 2012 at 7:10 pm
    I recorded an hour and twenty seven minutes of video that spanned three 16gb P2 cards.
    I copied the files (“contents” and “lastclip.txt) from P2 cards to my hard drive. When I try to import the mxf files from the various cards, all I get is multiple instances of the first 34 minutes instead of three clips containing part 1, part 2 and part 3.
    If I convert the files in Adobe Media Encoder, I get all the footage but I lose the original timecode and the audio gets converted into one discreet track. It also seems to scale my video too.
    I’m confused.
    David Tannenbaum replied 13 years, 3 months ago 3 Members · 3 Replies
  • Jon Barrie
    June 15, 2012 at 11:38 am
    Are you using the Media Browser to import the footage?
    Cheers JB 🙂
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Mark Whittle
    February 22, 2013 at 4:54 am
    I’m having the exact same problem. I have each card’s contents in its own folder but in the browser each folder appears to contain the same clip (the first part).
    In MXF4Mac player I can see that the other clips are there but Premiere doesn’t see them.
    Cheers,
    Mark
    Mark W.
  • David Tannenbaum
    June 12, 2013 at 6:00 pm
    Jon, yes I am using the media browser. I’m certain it’s some kind of a data base issue. Perhaps those xml files in the clip folder play a part. If I transcode the files everything is fine but then I end up with twice the data.
