Activity Forums Adobe Premiere Pro Premiere crashes when Bella Keyboard is attached
  • Premiere crashes when Bella Keyboard is attached
    Posted by Scott Williams on September 27, 2008 at 9:33 pm
    I’m still running Premiere Pro 1.5 on one of my older computers. A few days ago the power supply died, so I took the computer to a local computer repair shop where they ordered an exact replacement and installed it.
    When I started the computer up Windows would not launch. It appears my Bella editing keyboard is causing the problem. If I use a normal keyboard it launches fine. It also works if I unplug the keyboard and then plug it back in once Windows has launched.
    Along with this problem Premiere freezes whenever I try to play any video. Sometimes just Premiere freezes and other times the whole computer locks up and I have to do a manual restart.
    Video in After Effects 6.5 is still works fine.
    Any thoughts on what could be causing this?
    Scott
    Empyre Pyctures LLC
    Scott Williams replied 17 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
