Activity Forums Adobe Premiere Pro Premiere CC – Sequence preset for animation?
  • Premiere CC – Sequence preset for animation?
    Posted by Bill Dewald on September 11, 2013 at 1:07 pm
    Howdy –
    I’m playing around with creating an animated project in Premiere, and I can’t decide on a sequence preset.
    If I was in FCP7, I’d use a plain 1920×1080 24p ProRes sequence. All of the new sequence presets in Premiere seem to be based on camera codecs (Arri/DSLR/RED, etc.)
    I’ll be generating all of my footage digitally (in weird places like MS Paint, Autodesk Animator, maybe some After Effects). I don’t want Premiere to have to do a lot of work re-encoding the footage into a camera format.
    What’s the best sequence preset for non-camera footage?
    Ivan Myles replied 13 years ago 3 Members · 5 Replies
  • Ivan Myles
    September 11, 2013 at 4:03 pm
    [Bill Dewald] “I don’t want Premiere to have to do a lot of work re-encoding the footage into a camera format.”
    Premiere only re-encodes the source material for preview files, which are optional. This does not impact the delivered file unless you select “Use Previews” in the export settings.
    [Bill Dewald] “What’s the best sequence preset for non-camera footage?”
    Create a sequence based on your source material and delivery requirements. Some codecs only support specific combinations of settings (e.g. AVC-Intra, DNxHD, ProRes). Otherwise, here are some guidelines to create a custom sequence:
    – Animations typically use progressive scanning as opposed to interlaced fields.
    – Typical frame rates are 24, 25, and 30 fps. If all else is equal, use 25/50 fps if your local power is 50Hz (most of the world), and 30/60 fps in regions using 60Hz (e.g. North America).
    – Typical frame sizes are common SD/HD dimensions.
    – Audio sampling at 48kHz supports broadcast video, DVD, and blu-ray. It is not uncommon to use 44.1kHz, especially with music.
    – Use square pixels unless otherwise specified (e.g. DVD).
    – If the source material is RGB and the final delivered file will be YUV/YCC, select “Maximum Bit Depth” to reduce color conversion issues. Use only 32-bit effects within the project.
    – Select “Maximum Render Quality” if the dimensions will be rescaled.
  • Kevin Monahan
    September 11, 2013 at 4:47 pm
    Hi Bill,
    You can create a custom preset. Just head to the Settings tab in the New Sequence dialog box. Choose > Custom. Create all the settings you need. You can even set to preview renders with ProRes under Video Previews, choose > QuickTime, then you should be able to view ProRes codecs.
    See if that works for you.
    Kevin
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Bill Dewald
    September 12, 2013 at 9:50 pm
    I’ve built a custom sequence and it’s got me going just fine. Thanks, Ivan and Kevin!
  • Kevin Monahan
    September 12, 2013 at 10:49 pm
    Glad you got going, Bill!
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
  • Ivan Myles
    September 14, 2013 at 2:17 am
    Good to hear. Happy editing!
