Premiere CC not showing all 5.1 audio channels and make loud beep sounds. Bug maybe?
I’m having a problem or I found a bug that mess up my 5.1 audio when I bring a 5.1 export from
Adobe Audition CC to Premiere CC. Only the Left Channel shows up and the other are silent or
have this loud, long beep.This is the method I used:
Multirack > Export to Adobe Premiere Pro and choose Option, Mixdown session to: 5.1 File.
Check Open in Adobe Premiere Pro.
Now in Premiere CC, the 5.1 audio file does not show all channels.Now when I just find the same 5.1 file from my hard drive and drop it in to Premiere, the file show
all 6 channels and sound perfect. When exporting, am I doing something wrong?I think it might be that Premiere CC not reading the xml file, that made from Audition, correctly.
I did the same method with Premiere C6 and it worked.
