Activity Forums Adobe Premiere Pro Premiere CC multi-camera problems
  • Premiere CC multi-camera problems
    Posted by Hal Ray on February 5, 2014 at 7:42 am
    Hello,
    I shot a live show with 2 DSLR’s, both with audio recording.
    I’m new to multi camera workflow.
    I Tried to generate a multi camera sequence automatically from the clips by the audio waves,
    The problem is that the generated sequence show too many cameras, like 4 sometimes 8 different angels while I shot with only two cameras, I can see the correct two frames in the multi camera panel and a lot of other black frames, the orders of the camera also changing.
    This way I cannot use my keyboard to choose camera 1 or 2 because every few seconds it keeps changing.
    What did I do wrong?
    Do I need to choose different settings while I’m creating the multi-camera source sequence?
    Update:
    I Tried to make a sequence from all the clips from camera A and Camera B
    So I’ll have only two clips, Now when I generate a multi camera sequence I got only 2 cameras and I can work,BUT The sync is lost in the middle of the sequence, It seems it worked only for some of the show, while on the other sequence I did earlier with the wrong number of cameras presented, It stays in sync all the show.
    What goes wrong?
    now I edited the first half of the show with the sequence thats get out of sync, and now I try to continue editing from there with the sequence that stay in sync but have wrong number of cameras so the editing processes is more complicated but in sync, But when I change the cameras during playback (the red button indicate it recording my decisions) it seems fine but when I stop and go back to the timeline and play, Premiere didn’t do record and instead show a black screen or a stuck frame from the other out of sync sequence when I play the part I just Edited.
    I cannot continue editing.
    Why is that happening?
    How can I work with one functioning in sync sequence and how can I work with those two sequences on one timeline?
    btw what is nest?
    Thank you very much in advance.
    Hal Ray replied 12 years, 7 months ago 1 Member · 1 Reply
  • Hal Ray
    February 17, 2014 at 12:37 am
    up.
