Activity Forums Adobe Premiere Pro Premiere CC 2014 and Blackmagic Intensity Extreme
  • Premiere CC 2014 and Blackmagic Intensity Extreme
    Posted by Pelle Asselbergs on July 8, 2015 at 8:55 am
    I’m working on an project in PP 8.2.0 (on OSX 10.9.5 / nMac Pro) and when I connect my tv (hdmi) it shows up in the playback preference panel, but won’t output. Sound does output through the BM. Hope to hear some suggestions. BM Desktop Video is version 10.3.7 and works fine on same set up with FCP7. Thanks in advance, have a good day!
    Barry Cohen replied 11 years, 2 months ago 3 Members · 3 Replies
  • Justin Daniels
    July 8, 2015 at 8:25 pm
    Trick I found that helped me get picture…
    Go into Premiere’s preferences, then go to playback settings. Click the setup option for your Blackmagic. There should be a little box that opens with options “For output of unsupported frame sizes.” Depending on your timeline settings and TV, select either “scale up” or “scale” down.” For me, my TV supports all formats so “scale down” usually works best, but if I’m in a 1280×720 timeline, sometimes I have to choose “scale up” for the picture to be displayed. Hopefully this works for you too.
    If it doesn’t show up right away, leave it on scale up or scale down and restart premiere to refresh it’s “brain.”
  • Pelle Asselbergs
    July 9, 2015 at 7:25 am
    Hi Justin, thanks for your reply!
    I tried all options ‘no output’, ‘center’ and ‘scale to fit’. Did a reboot of PP after each try, no result…
    Timeline is 1920×1080 and pro res (proxy) and tv is plasma 50″, so full hd is possible.
    Hope you have another trick left! Have a nice day.
    Pelle
  • Barry Cohen
    July 9, 2015 at 6:04 pm
    I am not in front of the unit now but I seem to remember that the Blackmagic set up has to agree with the sequence set up in Premiere. That is they should both be 1080i or 720p and the frame rates should agree too.
    I hope this helps.
