Activity Forums Adobe Premiere Pro Premiere Capabilities: Can it do this….
  • Premiere Capabilities: Can it do this….
    Posted by Matt Green on May 21, 2008 at 5:55 am
    I have limited professional experience with softwares such as Premiere, however, I’m looking for a product that will allow me to create the following desired effect:
    Using default Premiere effects/macros or 3rd party plug-ins, is it possible to use the volume or frequencies of an audio track to manipulate the colors/palette of a video? For instance, low volumes result in a blue overlay while highs are red with other volumes represented dynamically by the range between the two set colors selected. I’m looking for a completely automatic application of this effect as basic keyframing simply won’t produce the accuracy or detail that I require.
    Mike Velte replied 18 years, 4 months ago 2 Members · 1 Reply
  • Mike Velte
    May 21, 2008 at 11:21 am
    After Effects can do that.
