Activity Forums Adobe Premiere Pro Premiere Audio Automation problem
  • Premiere Audio Automation problem
    Posted by James Wilde on May 5, 2010 at 8:50 pm
    Hello all. I have a rather interesting audio automation problem in Premiere. I currently have edited a 26min TV production of a sporting event and for the life of me, I cant get the audio write to work at all. I did create a new “TEST” project which works fine and all settings are the same, so not sure what the problem is. I am running Windows 7 (7600) and using CS3. If somebody does, let me know
    Alex Udell replied 16 years, 4 months ago 2 Members · 4 Replies
  • Alex Udell
    May 6, 2010 at 2:35 am
    Can you elaborate on what it’s not doing?
  • James Wilde
    May 6, 2010 at 8:48 am
    Hello Alex.
    If I select write from the drop down menu on any channel and select Show track keyframes, nothing happens after I press the space bar. If I go back to where I started on the timeline, the channel level jumps back to 0, if “Switch to touch after write” is selected and stays where it was if I stop the write, but no keyframes actually appear even though I can hear the audio change levels in the mixer as I do it. First time I have encountered this issue. I am also working across 2 monitors
  • James Wilde
    May 6, 2010 at 11:24 am
    I found the problem. I had accidentally clicked on the in-point button in the program window, which set an in-point towards the end of the production. Premiere likes the PROGRAM IN-POINT at the start. Problem sorted. Thanx
  • Alex Udell
    May 7, 2010 at 10:48 am
    great…snowed under at work….soeey for the lack of response…
    Alex
