Activity › Forums › Adobe Premiere Pro › Premiere and Edius on same computer?
  • Premiere and Edius on same computer?
    Posted by Zvi Twersky on November 23, 2007 at 9:21 am
    Some programs should NEVER be installed if you don’t really need them since they will leave permenant traces in your registry and memory even after UNinstalling them… (for example: Norton AV, AOL software… etc.)
    I use EDIUS on my computer (with Canopus) and on the other computers in our studio I use Premiere (with Matrox).
    I wanted to ask if it’s ok to install Premiere on my computer… even though there is no Matrox. I might use it for little projects or titles…
    I might even want to edit small projects while EDIUS is rendering.
    Will installing Premiere Pro conflict with the installed EDIUS software?
    Thank you.
    Blast1 replied 18 years, 10 months ago 3 Members · 2 Replies
  • Mike Velte
    November 23, 2007 at 12:38 pm
    I dont believe any software can be put in the same evil class as Norton, AOL and possibly Roxio.
    [Zvi_Twersky] “I might even want to edit small projects while EDIUS is rendering.”
    I have tried most NLE’s on systems with Premiere without conflict as long as they are not running at the same time. At the worst, the first NLE opened will tie up Window’s support for DirectShow (DV) capture and device control. You may not enough horsepower or RAM to have Edius rendering while trying to edit in Premiere, but try it.
  • Blast1
    November 23, 2007 at 6:13 pm
    I’m running Edius 4.54 on a dual-core laptop with Production Studio with no problems, I haven’t tried to run them at the same time, but have used AFX or PS at the same time.
