Activity Forums Adobe After Effects Premiere-After Effects Render Engine
  • Premiere-After Effects Render Engine
    Posted by Randy Mcwilson on January 17, 2008 at 5:43 am
    At NAB in 2007 I spoke with an Adobe project manager about the marked difference in the rendering quality between premiere pro and after effects. When comparing the same movement, or corner pin, or 3d move between the 2 programs on DV NTSC outputs, the difference is striking. AE is light years ahead in terms of sub-pixel interpolation, whereas premiere suffers from consistent “pixel-jumps” and overall low quality interpolation. If you will notice, in premiere pro, if you move a clip up or down one pixel the image quality will suffer drastically, you must move it on exact 2 pixel boundaries to keep quality.
    The Adobe rep said that all of those differences would be removed in CS3 and that ppro and AE would share an identical render engine. I have been using and tweaking both of the CS3 programs and still see no difference in the poor quality of premiere output. Is there a series of hidden or obscure settings that need to be activated or tweaked to achieve similar quality?
    I apologize for placing this in the AE forum, but I am going to place it in both to get a broader exposure to the issue.
    thanks
    Randy Mcwilson replied 18 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
