Premiere 6 (stop motion) feature, is there a simular feature found in Final Cut Pro
> Does final Cut Pro have a stop motion capture feature as does
Premiere 6.
> In Premier 6 there is a feature that allows you to capture a single
frame from a digital video source
one at a time and will sequence all the photos from that source to make
a stop motion animation.
> Does Final Cut Pro have a similar feature called stop motion under a
different name or will Final Cut Pro do stop motion animation at all?
> Stop motion is done by capturing single frames at a time and
playing them back 12 too 24 frames per second.
> thank you.
> Rick
