Activity Forums Adobe Premiere Pro Premier will only export MPEG4 with a max resolution of 352×288
  • Premier will only export MPEG4 with a max resolution of 352×288
    Posted by Josh Williams on August 9, 2014 at 7:09 pm
    Hi People,
    Another problem here..I love all the help Iv’e gotten in the past, appreciated guys
    So I have made a animation in after effects, exported it in AVI (uncompressed I think but not 100%) This took roughly 5-6 hours. I wanted to add some sound on to it which I have in Premier by adding in the exported clip rather then dynamic link.
    Now I want to export it into MPEG4 because it is going over to a mac where it will be added into a bigger project. The max it will export in is 352×288 and I have no idea why..
    I have also seen talk on the web of exporting into XML to then transfer to final cut, is this better and how do I do this?
    So yeah if anyone has any ideas please let me know!
    Again thanks guys!
    Josh
    Josh Williams replied 12 years, 1 month ago 2 Members · 2 Replies
  • Ann Bens
    August 9, 2014 at 9:37 pm
    Because you choose the wrong setting.
    If you want mp4 you choose H.264 as format
    If its for a mac set it to Quicktime and the codec Animation.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Josh Williams
    August 9, 2014 at 9:44 pm
    Great, thanks.
    I think it was a case of being misinformed on the other end!
    Thanks again
