Activity Forums Adobe Premiere Pro Premier project created on a pc open in Premiiere on a Mac?
  • Premier project created on a pc open in Premiiere on a Mac?
    Posted by Bill Maxwell on December 3, 2012 at 7:48 pm
    Hi…Will a Premiere project created on a pc open in Premiere on a Mac? Also…will a Premiere project created on a pc open in Final Cut 7…Thanks…Bill
    Bill
    Angelo Lorenzo replied 13 years, 9 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    December 5, 2012 at 2:59 am
    1) Yes, if they are the same version or if you are opening the project in a newer version of Premiere. You will be asked to relink files, but if they’re in the same folder structure that usually means finding one file and Premiere will recursively find the others.
    2) Yes, if you export your project as a final cut XML file, you will be able to open it in Final Cut on Mac. The same issue with relinking files will apply within Final Cut as well.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
