Activity › Forums › Adobe Premiere Pro › Premier Pro SDI out
Davib Le roux
January 18, 2012 at 2:49 pmThanks Chris, but i do not have that folder, i am aware of where it is supposed to be. I can’t understand why it isn’t there though, that is my issue.
Chris Tompkins
January 18, 2012 at 3:04 pmWhat a pain, That doesn’t make sense if you re-installed the BMD after installing APP – you should see it there.
Maybe a call into BMD support will fix it?Chris Tompkins
Video Atlanta LLC -
Petros Kolyvas
January 18, 2012 at 3:28 pmAnd if you’re looking for something to do while on the phone and/or before you call you can try the old:
– Uninstall BMD Drivers
– Trash Premiere’s Preferences and Settings
– Optional (Do some OSX maintenance using Onyx to clear caches, repair permissions and such)
– Reinstall BMD DriversHope it works out!
There is no intuitive interface, not even the nipple. It’s all learned. – Bruce Ediger -
Cory Pennington
October 22, 2014 at 4:39 pmThis worked for me: created black magic design timeline (unconfirmed if this is necessary) then under playback settings enabled Mercury transmit
Cory R. Pennington
http://www.jackalopecreative.com
