Activity Forums Adobe Premiere Pro Premier Pro opening Final Cut Exports
  • Premier Pro opening Final Cut Exports
    Posted by Shay Willard on February 22, 2007 at 4:35 am
    Is there any way to export from Final Cut pro and then open it with Premier Pro 1.5? I’ve tried both the avi and .mov, but both times I get an “unsupported file” or “sunsupported compression in file” error. How can I make the file types compatible!?
    -Rek
    Eric Addison replied 19 years, 7 months ago 2 Members · 3 Replies
  • Eric Addison
    February 22, 2007 at 4:31 pm
    When you export from FCP, make sure you use DV codec. And make sure that you make it a self-contained movie.
  • Shay Willard
    February 22, 2007 at 7:42 pm
    Which file types (avi, .mov, etc) have the DV codec available?
  • Eric Addison
    February 23, 2007 at 6:31 am
    Both Quicktime and AVI should over DV codec. The trick is that it has to be a self contained movie. Try using the convert to Quicktime under the export selection – that may help too.
