Activity Forums Adobe Premiere Pro Premier Pro CS3 skipping/shaking after export
  • Premier Pro CS3 skipping/shaking after export
    Posted by Rich Jones on March 10, 2009 at 5:14 pm
    Using .mpg movies in PremProCS3, along with a text title page and a .mov taken on IPhoto. After exporting to hardrive and or straight to dvd, all but the .mpg clips are fine… the .mpg are shaking and jittering etc……it plays fine in the PPro application…only when I export.
    what am I doing wrong, can someone provide me with the correct output settings when exporting or writing to dvd or enlighten me on what to do.
    Thanks in advance.
    Rich
    Rich Jones replied 17 years, 5 months ago 4 Members · 4 Replies
  • David Johnston
    March 13, 2009 at 2:52 am
    Hey Rich,
    Just had this problem myself. What I did to fix it was to right click on the offending video files in the timeline and go to Field Options. I just changed the Processing Options to “Always Deinterlace” and that seems to have fixed it for me.
    Good Luck!
  • Brydie Sheen
    March 13, 2009 at 11:08 pm
    wish i could help! i have the same prob but it is with the crawling text and the Boris crawling text which are FCP texts.
    everything plays smooth and sweet when played on the FCP sequence. Ive tried about 6 different ways to export the sequence into quicktime but when i play back the export version, the text jitters and staggers and depending on the settings i use to export – the images sometimes jitter.
    Im pretty sure it has something to do with with original settings and export settings…….which im sure you already knew!!
    Its very frustrating!!
    What Now?
  • Blaise Gerstung
    March 30, 2009 at 1:36 am
    Right click on the video file in the Timeline, and be sure “Frame Blend” is DESELECTED.
    That did it for me, hope it helps you out!
  • Rich Jones
    April 16, 2009 at 4:35 pm
    Thank You Blaise…….YOU SAVED MY PROJECT…….MUCH APPRECIATION.
    YEAH…
