Activity Forums Adobe Premiere Pro Premier Pro CC sudenly can’t open, what now?
  • Premier Pro CC sudenly can’t open, what now?
    Posted by Mark Suszko on January 8, 2018 at 7:42 pm
    I’m in OS X 10.10.5 Yosemite on an older iMac. Just really starting to play with Premiere. Everything was working for weeks, then this morning I updated firmware for the attached Blackmagic Designs Ultrastudio4k, which we use to play out to the rest of our plant. After a restart, Premier ProCC consistently hangs during startup and will not open, beachball city, force-quit.
    I checked for a CC Premiere update, none available. I uninstalled and re-installed Premiere ProCC, made no difference.
    Entertaining suggestions, with a bit of urgency.
    Brent Marginet replied 8 years, 8 months ago 4 Members · 5 Replies
  • Mark Suszko
    January 8, 2018 at 8:19 pm
    Update: Premiere Pro CC WILL come up properly, if the Blackmagic Ultrastudio4K is powered-down first.
    Next I will check if It keeps running if I restore power to the BMD4k once Premiere is up.
    Suggestions?
  • Mark Suszko
    January 8, 2018 at 8:21 pm
    Plugging the BMD 4k back in with the timeline open kills Premiere CC.
  • Tero Ahlfors
    January 8, 2018 at 9:48 pm
    Try trashing your preferences.
  • John Pale
    January 9, 2018 at 3:43 am
    Download the proper version of Blackmagic Desktop (firmware and drivers) for your OS and re-install them. Seems like the BMD device is causing the issue and you may have installed too recent a version for your device.
  • Brent Marginet
    January 9, 2018 at 6:19 am
    I second the post about the driver version you have installed.
    If you installed anything newer than 10.8.6 on Yosemite then you will have nothing but issues. I had one Yosemite system at one time where PP and Avid would not run properly or at all until I went back to V10.7.1 of the BM Drivers.
    \”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
