Activity Forums Adobe Premiere Pro Premier pro cc export issues
  • Derek Sajbel
    May 29, 2014 at 6:00 pm
    Had a similar issue on a gig yesterday, compressing prores 422 (LT) sources to h.264 we would get pink glitches and video skips on the exports.
    Our solution ended up being an old school solution. In adobe media encoder, in the queue section, at the bottom, make sure the Renderer is “Mercury Playback Engine Software Only”. I don’t know where you can change this setting if you are exporting directly out of premiere though.
    This fixed our problem, good luck!
  • Andy Edwards
    May 30, 2014 at 5:14 am
    Derek,
    Are you on Mavericks 10.9.3 with a new Mac Pro by chance? Those issues are common right now until Apple pushes out 10.9.4.
    Now where to change your setting when exporting from Premiere vs. Media Encoder queue:
    In Premiree Go to File Menu / Project settings / General tab / Video Rendering and Playback / change to software only.
    Andy Edwards
  • Chris Tompkins
    May 30, 2014 at 10:49 am
    Export a 25p version and check that.
    Chris
Page 2 of 2
