Activity Forums Adobe Premiere Pro Premier Pro AVI export only creating 24p video
  • Premier Pro AVI export only creating 24p video
    Posted by David Sapadin on December 28, 2009 at 5:42 am
    Hello:
    I’ve run into a Premier Pro 2.0 mystery I’ve not encountered before. I have a sequence that I want to export to avi. It is a mix of 16 x 9 video (not hi-def), and photos. Its a widescreen project. I’ve done this type of project before, never had this problem. When I export the sequence, the video is exported in 24P even though I have set the export settings to NTSC. I tried burning a disk from inside Premier using the not-so-wonderful disk burner that is included, and the video came out fine — 29.97 fps like its supposed to. But when I export to .avi (so I can bring it into ENCORE) the video is changed to 24P. What the heck is going on here? Any help greatly appreciated. I want to use ENCORE because its going to go onto a Dual Layer disk. And I have the menus already made.
    Thanks in advance,
    Dave
    David Sapadin replied 16 years, 9 months ago 1 Member · 2 Replies
  • David Sapadin
    December 28, 2009 at 6:12 pm
    Well I think I figured out the problem. The entire project is set to 24p. I can’t imagine how I opened a 24p project because I’ve never ever used one before. Can Premier change the project to 24p on its own? Anyway, now I need to know if there’s a way to cut and paste sequences out of this project and into a new one that is not set to 24p. I don’t even know if its possible…
    Dave
  • David Sapadin
    December 28, 2009 at 7:03 pm
    Problem solved I think. I was able to simply import the original project into a new one with the right settings. Tried a test export to AVI and voila. Normal. The only mystery that remains is, when I exported the original project to DVD using Premier’s Export to DVD, the video was normal, and NOT 24p, although the disk skipped alot – acted like the write was bad. Wheras when I exported the project to DVD using Encore, you could see immediately that the video was 24p. ???
