Activity Forums Adobe Premiere Pro Premier CS3 HDV project slow loading and..
  • Premier CS3 HDV project slow loading and..
    Posted by Darin Miyashiro on January 31, 2008 at 10:59 pm
    I have a HDV project in CS3 premier.
    It takes long time to load and also when I click outside
    of premier, the hourglass comes on and it takes at least
    30 seconds to use premier.
    The project is HDV and not very complex. I think I have
    3 sequences and the most layers I have in one sequence
    is 3 layers.
    System:
    Dell XPS410, Quad Q6600 2.4ghz
    4gigs ram
    Windows XP PRO
    Is this common for HDV projects?
    Darin
    Brian Kennell replied 18 years, 1 month ago 3 Members · 2 Replies
  • Baz Leffler
    February 1, 2008 at 12:47 am
    yes
    What would I do without the ‘UNDO’ button!!!!
  • Brian Kennell
    August 7, 2008 at 2:19 am
    Darin,
    How many clips do you have in your project? I typically have 500+ HDV (.m2t) files per project and to open a project takes 5-10min.
    I have a theory that if i don’t split up my .m2t files, the project load time will go down drastically. I have not tested this however. Do you capture via the Premiere Pro capture utility?
