Activity › Forums › Adobe Premiere Pro › Premier CC 2014 crashing
  • Kevin Monahan
    February 17, 2015 at 6:43 pm
  • Tom Adams
    February 17, 2015 at 8:16 pm
    Kevin, thanks for that link and info…I was really hoping that would do the trick… but still jittery playback…especially with real basic dissolves to still jpgs…
    it seems to help if I wait a second or two before I hit the spacebar to play after I’ve just moved cursor to new spot in timeline…but I shouldn’t have to wait for a response time like that should I?
    also I remember in my fcp days it was good to close down the audio track so no waveform is showing because that takes a lot of ram…but this seems silly since I just bought 16GB of ram to help with the processing speed. hmmmm….
  • Kevin Monahan
    February 18, 2015 at 8:59 pm
    Tom,
    I just noticed that you have an underpowered GPU. Can you check File > Project Settings > General and make sure that under Video Rendering and Playback, the Renderer is set to “Mercury Playback Engine Software Only.” See if that helps your situation.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Tom Adams
    February 19, 2015 at 4:11 pm
    Kevin, thanks again for your reply. I checked that “Mercury Playback Engine Software Only.”- and yes, it’s the only option and it’s greyed out.
    • a few other questions that might help…would getting a new graphics card(?) to replace my ‘ancient ATI Radeon HD 2600 XT 256 MB help?
    • attached screenshot 1: does changing the location of my cache files help? I saw a post saying I should store them all on my external firewire drives and not on my internal HD (screenshot2015-02-19at10.56.57am.jpg)
    • attached screenshot 2: apparently the default for a new sequence with my AVCHD, MTS files is “ARRI Cinema”… something I’m not familiar with at all… What should this be set at? (screenshot2015-02-19at10.56.57am.jpg)
    • attached screenshot 3: does the setting for optimized rendering or memory make a difference?
    thanks so much for any help you can lend…
    Regards,
    Tom Adams – Director/Owner
    Reelife Documentary Productions
    “cool digital video stuff…not boring or dumb”
    http://www.reelifeproductions.com
    Williamsburg, MA, USA
    http://www.FolktographybyTom.com
    https://Folktography.zenfolio.com
    MacPro
    Premiere ProCC 2014
    4TB Firewire Drives
    Panasonic AGAC90, Canon D60 DSLR
  • Tom Adams
    March 10, 2015 at 8:15 pm
    Kevin and anyone else who’d like to chime in…
    see my additional points/questions above… and I’ve pasted my crash report below… crashes are still happening
    Process: Adobe Premiere Pro CC 2014 [44173]
    Path: /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/MacOS/Adobe Premiere Pro CC 2014
    Identifier: com.adobe.AdobePremierePro
    Version: 8.2.0 (8.2.0)
    Code Type: X86-64 (Native)
    Parent Process: ??? [1]
    Responsible: Adobe Premiere Pro CC 2014 [44173]
    User ID: 501
    Date/Time: 2015-03-10 16:10:32.734 -0400
    OS Version: Mac OS X 10.10.2 (14C109)
    Report Version: 11
    Anonymous UUID: xxxxx
    Sleep/Wake UUID: D429AC51-AFD1-4C23-91FD-0675FFB07ACD
    Time Awake Since Boot: 460000 seconds
    Time Since Wake: 8600 seconds
    Crashed Thread: 21 Dispatch queue: com.apple.root.default-qos
    Exception Type: EXC_BAD_ACCESS (SIGSEGV)
    Exception Codes: KERN_INVALID_ADDRESS at 0x00000000000034a3
    VM Regions Near 0x34a3:
    __TEXT 0000000100000000-0000000100003000 [ 12K] r-x/rwx SM=COW /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/MacOS/Adobe Premiere Pro CC 2014
    Thread 0:: Dispatch queue: com.apple.main-thread
    0 libsystem_kernel.dylib 0x00007fff95c3a4de mach_msg_trap + 10
    1 libsystem_kernel.dylib 0x00007fff95c3964f mach_msg + 55
    2 com.apple.CoreFoundation 0x00007fff928ccb34 __CFRunLoopServiceMachPort + 212
    3 com.apple.CoreFoundation 0x00007fff928cbffb __CFRunLoopRun + 1371
    4 com.apple.CoreFoundation 0x00007fff928cb858 CFRunLoopRunSpecific + 296
    5 com.apple.HIToolbox 0x00007fff9581faef RunCurrentEventLoopInMode + 235
    6 com.apple.HIToolbox 0x00007fff9581f86a ReceiveNextEventCommon + 431
    7 com.apple.HIToolbox 0x00007fff9581f6ab _BlockUntilNextEventMatchingListInModeWithFilter + 71
    8 com.apple.AppKit 0x00007fff98414f81 _DPSNextEvent + 964
    9 com.apple.AppKit 0x00007fff98414730 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 194
    10 com.apple.AppKit 0x00007fff98408593 -[NSApplication run] + 594
    11 com.adobe.Frontend.framework 0x00000001000d302d FE::MacApplication::RunSelf() + 45
    12 com.adobe.Frontend.framework 0x0000000100047e98 FE::Application::Run(std::basic_string const&) + 4328
    13 com.adobe.Frontend.framework 0x00000001000d4944 FE::AppMain(ASL::ObjectPtr const&, std::basic_string const&, int, void*) + 276
    14 com.adobe.Frontend.framework 0x00000001000dbbe5 FE::Run(ASL::ObjectPtr const&, std::basic_string const&, int) + 581
    15 com.adobe.AdobePremierePro 0x00000001000018ac main + 508
    16 com.adobe.AdobePremierePro 0x00000001000016a4 start + 52
    Thread 1:: Dispatch queue: com.apple.libdispatch-manager
    0 libsystem_kernel.dylib 0x00007fff95c40232 kevent64 + 10
    1 libdispatch.dylib 0x00007fff973dda6a _dispatch_mgr_thread + 52
    Thread 2:
    0 libsystem_kernel.dylib 0x00007fff95c4021a kevent + 10
    1 com.adobe.dvatransport.framework 0x0000000100ea01a7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 375
    2 com.adobe.dvatransport.framework 0x0000000100e9fd18 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 552
    3 com.adobe.dvatransport.framework 0x0000000100e8f157 SkyConnectionEnv::MainLoop() + 167
    4 com.adobe.dvatransport.framework 0x0000000100e8ec09 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
    5 com.adobe.boost_threads.framework 0x00000001002c9dba thread_proxy + 186
    6 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    7 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    8 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 3:
    0 libsystem_kernel.dylib 0x00007fff95c3f136 __psynch_cvwait + 10
    1 com.adobe.dvacore.framework 0x00000001003a106b boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 139
    2 com.adobe.dvacore.framework 0x00000001003a0dd8 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 552
    3 com.adobe.dvacore.framework 0x00000001003a0b9a boost::asio::detail::posix_thread::func::run() + 42
    4 com.adobe.dvatransport.framework 0x0000000100ea0bb3 boost_asio_detail_posix_thread_function + 19
    5 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    6 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    7 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 4:
    1 com.apple.CoreServices.CarbonCore 0x00007fff968a17c0 TSWaitOnCondition + 108
    2 com.apple.CoreServices.CarbonCore 0x00007fff968a19bf TSWaitOnConditionTimedRelative + 171
    3 com.apple.CoreServices.CarbonCore 0x00007fff968712f5 MPWaitOnQueue + 192
    4 com.adobe.dvacore.framework 0x00000001003d923d dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 141
    5 com.adobe.dvacore.framework 0x00000001003d71a0 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 160
    6 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    7 com.adobe.dvacore.framework 0x00000001003d4113 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 115
    8 com.adobe.boost_threads.framework 0x00000001002c9dba thread_proxy + 186
    9 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    10 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    11 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 5:
    1 com.apple.CoreServices.CarbonCore 0x00007fff968a19a7 TSWaitOnConditionTimedRelative + 147
    2 com.apple.CoreServices.CarbonCore 0x00007fff968712f5 MPWaitOnQueue + 192
    3 com.adobe.dvacore.framework 0x00000001003d923d dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 141
    4 com.adobe.dvacore.framework 0x00000001003d71a0 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 160
    5 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    6 com.adobe.dvacore.framework 0x00000001003d4113 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 115
    7 com.adobe.boost_threads.framework 0x00000001002c9dba thread_proxy + 186
    8 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    9 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    10 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 6:
    Thread 7:
    Thread 8:
    5 com.apple.AVCVideoServices 0x000000011ea37c32 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 194
    Thread 9:
    Thread 10:
    Thread 11:
    Thread 12:
    0 libsystem_kernel.dylib 0x00007fff95c3f48a __semwait_signal + 10
    1 com.adobe.ScriptLayerPPro.framework 0x0000000107229868 ScObjects::Thread::wait(unsigned int) + 56
    2 com.adobe.ScriptLayerPPro.framework 0x000000010720fdee ScObjects::BridgeTalkThread::run() + 174
    3 com.adobe.ScriptLayerPPro.framework 0x0000000107229405 ScObjects::Thread::go(void*) + 165
    4 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    5 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    6 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 13:
    0 libsystem_kernel.dylib 0x00007fff95c3f33a __recvfrom + 10
    1 VulcanMessage5.dylib 0x000000011277ab32 vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 24
    2 VulcanMessage5.dylib 0x0000000112778c40 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 112
    3 VulcanMessage5.dylib 0x0000000112778cae vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 60
    4 VulcanMessage5.dylib 0x00000001127717d0 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 70
    5 VulcanMessage5.dylib 0x0000000112772262 vcfoundation::io::Serializer::InternalDeserialize() + 30
    6 VulcanMessage5.dylib 0x000000011277216f vcfoundation::io::Serializer::Deserialize() + 9
    7 VulcanMessage5.dylib 0x0000000112777782 vcfoundation::ncomm::Connection::ReadIn() + 28
    8 VulcanMessage5.dylib 0x00000001127778c6 vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 40
    9 VulcanMessage5.dylib 0x0000000112777681 vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 109
    10 VulcanMessage5.dylib 0x00000001127775fa vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 32
    11 VulcanMessage5.dylib 0x000000011276832b adobe::vulcan::servicemgr::CSIRequest::Execute() + 53
    12 VulcanMessage5.dylib 0x0000000112769507 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 353
    13 VulcanMessage5.dylib 0x00000001127782d0 vcfoundation::thread::AbstractThread::Run() + 50
    14 VulcanMessage5.dylib 0x000000011277c523 vcfoundation::thread::Thread::ThreadProc(void*) + 9
    15 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    16 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    17 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 14:: com.apple.audio.IOThread.client
    2 com.apple.audio.CoreAudio 0x00007fff9b0a2980 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98
    3 com.apple.audio.CoreAudio 0x00007fff9b0a290e HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
    4 com.apple.audio.CoreAudio 0x00007fff9b0a0f60 HALC_ProxyIOContext::IOWorkLoop() + 952
    5 com.apple.audio.CoreAudio 0x00007fff9b0a0b0e HALC_ProxyIOContext::IOThreadEntry(void*) + 88
    6 com.apple.audio.CoreAudio 0x00007fff9b0a09eb HALB_IOThread::Entry(void*) + 157
    7 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    8 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    9 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 15:
    2 com.apple.CoreServices.CarbonCore 0x00007fff9689e9ce TS_exception_listener_thread + 100
    3 libsystem_pthread.dylib 0x00007fff992d7268 _pthread_body + 131
    4 libsystem_pthread.dylib 0x00007fff992d71e5 _pthread_start + 176
    5 libsystem_pthread.dylib 0x00007fff992d541d thread_start + 13
    Thread 16:
    Thread 17:
    5 com.apple.AppKit 0x00007fff9857833b _NSEventThread + 137
    Thread 18:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001037dab7a void (anonymous namespace)::GenerateOffsetsAndFactors_SSE2(IR_POINTf, IR_POINTf const&, int, int*, int*, float*) + 340
    1 com.adobe.ImageRenderer.framework 0x00000001037dbb50 void Motion::InterpolateSample_SSE2<(IR_AlphaChannel)4, (IR_ColorSpace)0, (IR_PixelDepth)0, B_Pixel, false>(void const*, int, RECT const&, IR_POINTf, IR::ResampleKernel const*, IR::ResampleKernel const*, F_Pixel*, int&, int&) + 890
    2 com.adobe.ImageRenderer.framework 0x00000001037da415 Motion::RenderRows(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 683
    3 com.adobe.ImageRenderer.framework 0x00000001037db25e Motion::ExecuteWorkUnit(int) + 134
    4 com.adobe.dvacore.framework 0x00000001003d17bf boost::detail::function::void_function_obj_invoker2, void, int, int>::invoke(boost::detail::function::function_buffer&, int, int) + 31
    5 com.adobe.dvacore.framework 0x00000001003d137c boost::function2::operator()(int, int) const + 28
    6 com.adobe.dvacore.framework 0x00000001003d030d dvacore::threads::(anonymous namespace)::MultithreadedTask::Execute() + 141
    7 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    8 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    9 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    10 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    11 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    12 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    13 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 19:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001038100b4 void (anonymous namespace)::Convert422_8uToVUYA_4444_8u<(IR_Endian)4096>(void const*, void*, int) + 190
    1 com.adobe.ImageRenderer.framework 0x0000000103808c7d IR::LineConverter::Convert(void const*, void*, int) const + 57
    2 com.adobe.ImageRenderer.framework 0x00000001038163ff IR::ConvertPackedLineByLine(void const*, int, IR_PixelFormat, void*, int, IR_PixelFormat, int, int, dvamediatypes::RenderQuality) + 187
    3 com.adobe.ImageRenderer.framework 0x00000001037872f4 IR_Convert + 1256
    4 com.adobe.ImageRenderer.framework 0x00000001037879b1 IR_ScaleConvertOneField + 1573
    5 com.adobe.ImageRenderer.framework 0x000000010378795f IR_ScaleConvertOneField + 1491
    6 com.adobe.ImageRenderer.framework 0x0000000103787385 IR_ScaleConvert + 81
    7 com.adobe.VideoFrame.framework 0x00000001039d7c8c VF::VideoFrameManipulators::CopyFrameWithFields(ASL::InterfaceRef, ASL::InterfaceRef, dvamediatypes::RenderQuality, dvamediatypes::FieldType) + 1884
    8 com.adobe.VideoRenderer.framework 0x00000001053de827 ML::RenderableSourceScaler::GetFrameForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) + 903
    9 com.adobe.VideoRenderer.framework 0x00000001053e6715 ML::RenderableSourceTimeMix::GetFrameForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) + 245
    10 com.adobe.VideoRenderer.framework 0x00000001053c38ea ML::MediaNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 1178
    11 com.adobe.VideoRenderer.framework 0x00000001053a8986 ML::ClipNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 1814
    12 com.adobe.VideoRenderer.framework 0x00000001053ad96b ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 587
    13 com.adobe.VideoRenderer.framework 0x0000000105365b11 ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector const&, bool) + 193
    14 com.adobe.VideoRenderer.framework 0x000000010538eb96 ML::RenderableCutlistSource::GetFrameForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) + 230
    15 com.adobe.VideoRenderer.framework 0x00000001053de504 ML::RenderableSourceScaler::GetFrameForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) + 100
    16 com.adobe.VideoRenderer.framework 0x00000001053e6715 ML::RenderableSourceTimeMix::GetFrameForSampleTimes(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) + 245
    17 com.adobe.VideoRenderer.framework 0x00000001053c38ea ML::MediaNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 1178
    18 com.adobe.VideoRenderer.framework 0x00000001053a8986 ML::ClipNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 1814
    19 com.adobe.VideoRenderer.framework 0x00000001053ad96b ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 587
    20 com.adobe.VideoRenderer.framework 0x0000000105365b11 ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector const&, bool) + 193
    21 com.adobe.VideoRenderer.framework 0x0000000105406eda ML::RenderFrameRequest::Render(dvamediatypes::PixelFormat) + 938
    22 com.adobe.VideoRenderer.framework 0x00000001053f4f83 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) const + 211
    23 com.adobe.VideoRenderer.framework 0x00000001053f695c ML::RenderFrameQueue::ServiceQueue(bool) + 172
    24 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    25 com.adobe.dvacore.framework 0x00000001003c650c dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 12
    26 com.adobe.dvacore.framework 0x00000001003c538d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr const&) + 189
    27 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    28 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    29 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    30 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    31 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    32 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    33 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 20:
    0 libsystem_kernel.dylib 0x00007fff95c3f94a __workq_kernreturn + 10
    1 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 21 Crashed:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.VideoFilterHost.framework 0x0000000105d9aa5e ML::AEEffectReference::SetSubTreeRender(ASL::InterfaceRef) + 46
    1 com.adobe.VideoFilterHost.framework 0x0000000105d3199c ML::AEVideoFilter::RenderFilter(dvamediatypes::TickTime const&, dvamediatypes::TickTime const&, dvamediatypes::FrameRate const&, long long, long long, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, BE::FilterRenderParameters&, dvacore::utility::SmallBlockAllocator::vector const&, ASL::InterfaceRef&) + 332
    2 com.adobe.VideoFilterHost.framework 0x0000000105d59194 ML::AEVideoFilter::Render(BE::TransitionParams const&, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, int, int, dvamediatypes::TickTime const&, dvamediatypes::FrameRate const&, int) + 852
    3 com.adobe.VideoFilterHost.framework 0x0000000105d594f3 non-virtual thunk to ML::AEVideoFilter::Render(BE::TransitionParams const&, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, ASL::InterfaceRef, int, int, dvamediatypes::TickTime const&, dvamediatypes::FrameRate const&, int) + 51
    4 com.adobe.VideoRenderer.framework 0x00000001053d81bb ML::TransitionNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 2731
    5 com.adobe.VideoRenderer.framework 0x00000001053ad96b ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 587
    6 com.adobe.VideoRenderer.framework 0x0000000105365b11 ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector const&, bool) + 193
    7 com.adobe.VideoRenderer.framework 0x0000000105406eda ML::RenderFrameRequest::Render(dvamediatypes::PixelFormat) + 938
    8 com.adobe.VideoRenderer.framework 0x00000001053f4f83 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) const + 211
    9 com.adobe.VideoRenderer.framework 0x00000001053f695c ML::RenderFrameQueue::ServiceQueue(bool) + 172
    10 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    11 com.adobe.dvacore.framework 0x00000001003c650c dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 12
    12 com.adobe.dvacore.framework 0x00000001003c538d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr const&) + 189
    13 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    14 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    15 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    16 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    17 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    18 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    19 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 22:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001037801ed void (anonymous namespace)::CompositeOneRow_4444_8u(void const*, void const*, void*, int, float) + 295
    1 com.adobe.ImageRenderer.framework 0x0000000103779c01 (anonymous namespace)::MultiThreadedComposite::DoComposite(int, int) + 2473
    2 com.adobe.ImageRenderer.framework 0x000000010377cb4b IR_Composite + 553
    3 com.adobe.ImageRenderer.framework 0x000000010377ccce IR_CompositeWithBlendMode + 152
    4 com.adobe.ImageRenderer.framework 0x00000001037da4e7 Motion::RenderRows(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 893
    5 com.adobe.ImageRenderer.framework 0x00000001037db25e Motion::ExecuteWorkUnit(int) + 134
    6 com.adobe.dvacore.framework 0x00000001003d17bf boost::detail::function::void_function_obj_invoker2, void, int, int>::invoke(boost::detail::function::function_buffer&, int, int) + 31
    7 com.adobe.dvacore.framework 0x00000001003d137c boost::function2::operator()(int, int) const + 28
    8 com.adobe.dvacore.framework 0x00000001003d030d dvacore::threads::(anonymous namespace)::MultithreadedTask::Execute() + 141
    9 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    10 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    11 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    12 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    13 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    14 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    15 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 23:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x000000010381154b void (anonymous namespace)::Convert4444_32fTo4444_8u_SSE2(void const*, void*, int) + 159
    1 com.adobe.ImageRenderer.framework 0x0000000103808f40 IR::LineConverter::Convert(void const*, void*, int) const + 764
    2 com.adobe.ImageRenderer.framework 0x0000000103779bdc (anonymous namespace)::MultiThreadedComposite::DoComposite(int, int) + 2436
    3 com.adobe.ImageRenderer.framework 0x000000010377cb4b IR_Composite + 553
    4 com.adobe.ImageRenderer.framework 0x000000010377ccce IR_CompositeWithBlendMode + 152
    5 com.adobe.ImageRenderer.framework 0x00000001037da4e7 Motion::RenderRows(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 893
    6 com.adobe.ImageRenderer.framework 0x00000001037db25e Motion::ExecuteWorkUnit(int) + 134
    7 com.adobe.dvacore.framework 0x00000001003d17bf boost::detail::function::void_function_obj_invoker2, void, int, int>::invoke(boost::detail::function::function_buffer&, int, int) + 31
    8 com.adobe.dvacore.framework 0x00000001003d137c boost::function2::operator()(int, int) const + 28
    9 com.adobe.dvacore.framework 0x00000001003d030d dvacore::threads::(anonymous namespace)::MultithreadedTask::Execute() + 141
    10 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    11 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    12 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    13 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    14 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    15 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    16 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 24:
    Thread 25:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x0000000103866773 y8_dv_decode_huffman_dcac_sse2 + 499
    Thread 26:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001037ae811 void (anonymous namespace)::GetSolidPixels_SIMD(void const*, int, int const*, int const*, int, float const*, F_Pixel*) + 259
    1 com.adobe.ImageRenderer.framework 0x00000001037dbb76 void Motion::InterpolateSample_SSE2<(IR_AlphaChannel)4, (IR_ColorSpace)0, (IR_PixelDepth)0, B_Pixel, false>(void const*, int, RECT const&, IR_POINTf, IR::ResampleKernel const*, IR::ResampleKernel const*, F_Pixel*, int&, int&) + 928
    Thread 27:
    Thread 28:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001038091d4 (anonymous namespace)::Convert4444_32fTo4444_8u_NotNormalized(void const*, void*, int) + 176
    1 com.adobe.ImageRenderer.framework 0x000000010380ad9d (anonymous namespace)::ConvertBGRA_4444_8uToVUYA_4444_8u_709(void const*, void*, int) + 237
    2 com.adobe.ImageRenderer.framework 0x0000000103808f5c IR::LineConverter::Convert(void const*, void*, int) const + 792
    3 com.adobe.ImageRenderer.framework 0x00000001038163ff IR::ConvertPackedLineByLine(void const*, int, IR_PixelFormat, void*, int, IR_PixelFormat, int, int, dvamediatypes::RenderQuality) + 187
    4 com.adobe.ImageRenderer.framework 0x00000001037872f4 IR_Convert + 1256
    5 com.adobe.ImageRenderer.framework 0x000000010377ca80 IR_Composite + 350
    6 com.adobe.ImageRenderer.framework 0x000000010377ccce IR_CompositeWithBlendMode + 152
    7 com.adobe.ImageRenderer.framework 0x00000001037da4e7 Motion::RenderRows(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 893
    8 com.adobe.ImageRenderer.framework 0x00000001037db25e Motion::ExecuteWorkUnit(int) + 134
    9 com.adobe.dvacore.framework 0x00000001003d17bf boost::detail::function::void_function_obj_invoker2, void, int, int>::invoke(boost::detail::function::function_buffer&, int, int) + 31
    10 com.adobe.dvacore.framework 0x00000001003d137c boost::function2::operator()(int, int) const + 28
    11 com.adobe.dvacore.framework 0x00000001003d030d dvacore::threads::(anonymous namespace)::MultithreadedTask::Execute() + 141
    12 com.adobe.dvacore.framework 0x00000001003d0f36 dvacore::threads::(anonymous namespace)::MultithreadedTask::Join() + 22
    13 com.adobe.dvacore.framework 0x00000001003cf59e dvacore::threads::ExecuteCPUBoundTaskOnAllProcessors(boost::function const&, int) + 126
    14 com.adobe.ImageRenderer.framework 0x000000010380698b IR::Threading::ExecuteMultithreaded(IR::Threading::Task&) + 139
    15 com.adobe.ImageRenderer.framework 0x00000001037d9a31 Motion::RenderRowsThreaded(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 109
    16 com.adobe.ImageRenderer.framework 0x00000001037d8fdb Motion::Render() + 2729
    17 com.adobe.ImageRenderer.framework 0x00000001037d8123 MotionWithBlendMode(void const*, int, int, int, IR_PixelFormat, dvamediatypes::FieldType, RECT const*, void*, int, int, int, IR_PixelFormat, dvamediatypes::FieldType, unsigned int, unsigned int, IR_POINTf, IR_POINTf, IR_POINTf, double, float, bool, double, bool, IR_BlendMode, IR_ApplyMotionToField, dvamediatypes::RenderQuality, bool) + 2071
    18 com.adobe.ImageRenderer.framework 0x00000001037d82d0 IR_Motion + 150
    19 com.adobe.VideoRenderer.framework 0x0000000105369279 ML::(anonymous namespace)::InternalHandleSingleMotion(ASL::InterfaceRef const&, ASL::InterfaceRef const&, ML::IntrinsicParams const&, ML::CutlistRenderParams const&, bool, IR_ApplyMotionToField) + 1833
    20 com.adobe.VideoRenderer.framework 0x00000001053671bc ML::PerformIntrinsicOperations(ASL::InterfaceRef, ML::IntrinsicParams const&, ML::IntrinsicParams const&, ASL::InterfaceRef, ML::CutlistRenderParams const&) + 2604
    21 com.adobe.VideoRenderer.framework 0x00000001053ada50 ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 816
    22 com.adobe.VideoRenderer.framework 0x0000000105365b11 ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector const&, bool) + 193
    23 com.adobe.VideoRenderer.framework 0x0000000105406eda ML::RenderFrameRequest::Render(dvamediatypes::PixelFormat) + 938
    24 com.adobe.VideoRenderer.framework 0x00000001053f4f83 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) const + 211
    25 com.adobe.VideoRenderer.framework 0x00000001053f695c ML::RenderFrameQueue::ServiceQueue(bool) + 172
    26 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    27 com.adobe.dvacore.framework 0x00000001003c650c dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 12
    28 com.adobe.dvacore.framework 0x00000001003c538d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr const&) + 189
    29 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    30 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    31 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    32 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    33 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    34 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    35 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 29:
    Thread 30:
    0 libsystem_pthread.dylib 0x00007fff992d5400 start_wqthread + 0
    Thread 31:: Dispatch queue: com.apple.root.default-qos
    1 com.adobe.dvacore.framework 0x0000000100357566 void boost::condition_variable_any::wait(boost::unique_lock&) + 70
    2 com.adobe.dvacore.framework 0x00000001003cb965 dvacore::threads::WaitableGateBase::PassThrough(int) const + 277
    3 com.adobe.dvacore.framework 0x00000001003cb5dc dvacore::threads::Gate::PassThrough(int) const + 12
    4 com.adobe.dvacore.framework 0x00000001003cf59e dvacore::threads::ExecuteCPUBoundTaskOnAllProcessors(boost::function const&, int) + 126
    5 com.adobe.ImageRenderer.framework 0x000000010380698b IR::Threading::ExecuteMultithreaded(IR::Threading::Task&) + 139
    6 com.adobe.ImageRenderer.framework 0x00000001037d9a31 Motion::RenderRowsThreaded(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 109
    7 com.adobe.ImageRenderer.framework 0x00000001037d8fdb Motion::Render() + 2729
    8 com.adobe.ImageRenderer.framework 0x00000001037d8123 MotionWithBlendMode(void const*, int, int, int, IR_PixelFormat, dvamediatypes::FieldType, RECT const*, void*, int, int, int, IR_PixelFormat, dvamediatypes::FieldType, unsigned int, unsigned int, IR_POINTf, IR_POINTf, IR_POINTf, double, float, bool, double, bool, IR_BlendMode, IR_ApplyMotionToField, dvamediatypes::RenderQuality, bool) + 2071
    9 com.adobe.ImageRenderer.framework 0x00000001037d82d0 IR_Motion + 150
    10 com.adobe.VideoRenderer.framework 0x0000000105369279 ML::(anonymous namespace)::InternalHandleSingleMotion(ASL::InterfaceRef const&, ASL::InterfaceRef const&, ML::IntrinsicParams const&, ML::CutlistRenderParams const&, bool, IR_ApplyMotionToField) + 1833
    11 com.adobe.VideoRenderer.framework 0x00000001053671bc ML::PerformIntrinsicOperations(ASL::InterfaceRef, ML::IntrinsicParams const&, ML::IntrinsicParams const&, ASL::InterfaceRef, ML::CutlistRenderParams const&) + 2604
    12 com.adobe.VideoRenderer.framework 0x00000001053ada50 ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 816
    14 com.adobe.VideoRenderer.framework 0x0000000105406eda ML::RenderFrameRequest::Render(dvamediatypes::PixelFormat) + 938
    15 com.adobe.VideoRenderer.framework 0x00000001053f4f83 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) const + 211
    16 com.adobe.VideoRenderer.framework 0x00000001053f695c ML::RenderFrameQueue::ServiceQueue(bool) + 172
    17 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    18 com.adobe.dvacore.framework 0x00000001003c650c dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 12
    19 com.adobe.dvacore.framework 0x00000001003c538d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr const&) + 189
    20 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    21 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    22 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    23 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    24 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    25 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    26 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 32:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001037ae795 void (anonymous namespace)::GetSolidPixels_SIMD(void const*, int, int const*, int const*, int, float const*, F_Pixel*) + 135
    Thread 33:
    Thread 34:
    Thread 35:
    Thread 36:
    Thread 37:: Dispatch queue: com.apple.root.default-qos
    0 com.adobe.ImageRenderer.framework 0x00000001037ae799 void (anonymous namespace)::GetSolidPixels_SIMD(void const*, int, int const*, int const*, int, float const*, F_Pixel*) + 139
    7 com.adobe.dvacore.framework 0x00000001003d0f36 dvacore::threads::(anonymous namespace)::MultithreadedTask::Join() + 22
    8 com.adobe.dvacore.framework 0x00000001003cf59e dvacore::threads::ExecuteCPUBoundTaskOnAllProcessors(boost::function const&, int) + 126
    9 com.adobe.ImageRenderer.framework 0x000000010380698b IR::Threading::ExecuteMultithreaded(IR::Threading::Task&) + 139
    10 com.adobe.ImageRenderer.framework 0x00000001037d9a31 Motion::RenderRowsThreaded(void const*, int, IR_PixelFormat, RECT const&, IR_POINTf, int, int, IR_ApplyMotionToField) + 109
    11 com.adobe.ImageRenderer.framework 0x00000001037d8fdb Motion::Render() + 2729
    12 com.adobe.ImageRenderer.framework 0x00000001037d8123 MotionWithBlendMode(void const*, int, int, int, IR_PixelFormat, dvamediatypes::FieldType, RECT const*, void*, int, int, int, IR_PixelFormat, dvamediatypes::FieldType, unsigned int, unsigned int, IR_POINTf, IR_POINTf, IR_POINTf, double, float, bool, double, bool, IR_BlendMode, IR_ApplyMotionToField, dvamediatypes::RenderQuality, bool) + 2071
    13 com.adobe.ImageRenderer.framework 0x00000001037d82d0 IR_Motion + 150
    14 com.adobe.VideoRenderer.framework 0x0000000105369279 ML::(anonymous namespace)::InternalHandleSingleMotion(ASL::InterfaceRef const&, ASL::InterfaceRef const&, ML::IntrinsicParams const&, ML::CutlistRenderParams const&, bool, IR_ApplyMotionToField) + 1833
    15 com.adobe.VideoRenderer.framework 0x00000001053671bc ML::PerformIntrinsicOperations(ASL::InterfaceRef, ML::IntrinsicParams const&, ML::IntrinsicParams const&, ASL::InterfaceRef, ML::CutlistRenderParams const&) + 2604
    16 com.adobe.VideoRenderer.framework 0x00000001053ada50 ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 816
    17 com.adobe.VideoRenderer.framework 0x0000000105365b11 ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector const&, bool) + 193
    18 com.adobe.VideoRenderer.framework 0x0000000105406eda ML::RenderFrameRequest::Render(dvamediatypes::PixelFormat) + 938
    19 com.adobe.VideoRenderer.framework 0x00000001053f4f83 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) const + 211
    20 com.adobe.VideoRenderer.framework 0x00000001053f695c ML::RenderFrameQueue::ServiceQueue(bool) + 172
    21 com.adobe.dvacore.framework 0x00000001003c763c boost::function0::operator()() const + 28
    22 com.adobe.dvacore.framework 0x00000001003c650c dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 12
    23 com.adobe.dvacore.framework 0x00000001003c538d dvacore::threads::(anonymous namespace)::SubExecutorImpl::OnThreadExecute(boost::shared_ptr const&) + 189
    24 com.adobe.dvacore.framework 0x00000001003daf2f dvacore::threads::ExecuteTopLevelFunction(dvacore::threads::AllocatedFunctionT const&) + 31
    25 com.adobe.dvacore.framework 0x00000001003dac1f dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
    26 libdispatch.dylib 0x00007fff973dac13 _dispatch_client_callout + 8
    27 libdispatch.dylib 0x00007fff973dd88f _dispatch_root_queue_drain + 935
    28 libdispatch.dylib 0x00007fff973ebfe4 _dispatch_worker_thread3 + 91
    29 libsystem_pthread.dylib 0x00007fff992d7637 _pthread_wqthread + 729
    30 libsystem_pthread.dylib 0x00007fff992d540d start_wqthread + 13
    Thread 38:
    Thread 39:
    Thread 40:: Dispatch queue: com.apple.root.default-qos
    Thread 41:
    1 com.mainconcept.mc.bc.dec.avc 0x000000011fe10f7d h264in_Video_GetAPIExt + 238477
    2 com.mainconcept.mc.bc.dec.avc 0x000000011fd890b5 open_h264in_Video_stream + 347941
    Thread 42:
    Thread 43:
    Thread 44:
    Thread 45:
    Thread 46:
    Thread 47:
    Thread 48:
    Thread 21 crashed with X86 Thread State (64-bit):
    rax: 0x000000000000349b rbx: 0x0000000132ff4b00 rcx: 0x0000000000000001 rdx: 0x000000012c416e90
    rdi: 0x0000000132ff8ac0 rsi: 0x0000000132ff4b08 rbp: 0x000000012c416ec0 rsp: 0x000000012c416b58
    r8: 0xf0445dea698369c3 r9: 0x000000012c418000 r10: 0x000000012c417208 r11: 0x000000000000000b
    r12: 0x000000015b1380d8 r13: 0x0000000000000000 r14: 0x000000015b138000 r15: 0x000000015b138ec8
    rip: 0x0000000105d9aa5e rfl: 0x0000000000010206 cr2: 0x00000000000034a3
    Logical CPU: 0
    Error Code: 0x00000004
    Trap Number: 14
    Binary Images:
    0x100000000 – 0x100002ff7 +com.adobe.AdobePremierePro (8.2.0 – 8.2.0) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/MacOS/Adobe Premiere Pro CC 2014
    0x10000a000 – 0x10000dfff +com.adobe.AdobeCrashReporter (7.1 – 7.1.4) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
    0x100014000 – 0x10013eff7 +com.adobe.Frontend.framework (8.2.0 – 8.2.0.65) <10E60FE1-B081-30F2-BA05-11DB2DDC89D1> /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
    0x100291000 – 0x100294ff7 +com.adobe.PRM.framework (8.2.0 – 8.2.0.65) <96EF748C-B7FA-35EE-A8F5-1118EC3BA5E8> /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
    0x1002a0000 – 0x1002a2fff +com.adobe.boost_system.framework (8.2.0 – 8.2.0.65) <215A7D7A-A0C6-34B1-9CFA-3D77CFEF0066> /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
    0x1002ab000 – 0x1002b1fff +com.adobe.boost_date_time.framework (8.2.0 – 8.2.0.65) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
    0x1002c8000 – 0x1002d6fff +com.adobe.boost_threads.framework (8.2.0 – 8.2.0.65) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
    0x1002f5000 – 0x100585fff +com.adobe.dvacore.framework (8.2.0 – 8.2.0.65) <4F18794A-4D20-35AE-9772-D955505EA67E> /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
    0x1007da000 – 0x100810ff7 +com.adobe.dvamediatypes.framework (8.2.0 – 8.2.0.65) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
    0x100847000 – 0x100896fff +com.adobe.ASLFoundation.framework (8.2.0 – 8.2.0.65) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
    0x100902000 – 0x10098efff +com.adobe.headlights.LogSessionFramework (7.2.1.3399) <4D4A32E1-2B7F-34AC-A310-B842CABE6080> /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
    0x1009d5000 – 0x100ad5fff +com.adobe.amtlib (8.0.0.145 – 8.0.0.145) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
    0x100ae8000 – 0x100b9cfff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 14 – 79.156821) <02275E92-9933-37D7-94DD-95AECE4516E0> /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
    0x100c48000 – 0x100d67fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 118 – 79.156821) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
    0x100e1b000 – 0x100e2bff7 +com.adobe.ASLMessaging.framework (8.2.0 – 8.2.0.65) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
    0x100e45000 – 0x100e46fff +com.adobe.Memory.framework (8.2.0 – 8.2.0.65) /Applications/Adobe Premiere Pro CC 2014/Adobe Premiere Pro CC 2014.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
    0x100e4d000 –
