Activity Forums Adobe Premiere Pro Premier 6 Won’t Recognize my AcedVio 1394 Capture Card…!
  • Premier 6 Won’t Recognize my AcedVio 1394 Capture Card…!
    Posted by William Witkowski on May 21, 2005 at 6:03 pm
    Hello Group, Premier 6 will NOT recognize my AcedVio 1394 capture card. Wondering if I should get Premier Pro 1.5? ? ?
    I really like Premier 6 for capturing video, is Premier Pro 1.5 similar?
    And will Premier Pro 1.5 recognize the card?
    Anyone…!
    B_W
    David J replied 21 years, 3 months ago 2 Members · 2 Replies
  • William Witkowski
    May 22, 2005 at 1:51 am
    Hello Group, Nevermind this post as I ‘fiddles’ with the software and the hardware and got it working. Ended up applying a firmware update to the AcedVio Card.
    I can now capture in Premier Pro, Premier 6 and Vegas… although I AM DISSAPOINTED that the preview window in Premire 6 and in Pro have such AWFULL color/contrast displays…!
    Must need further tweaking… as Premier 6 and Pro both introduce ‘vertical video’ ‘Noise’ that IS NOT IN THE ORIGINAL.
    Maybe back to the drawing board..!
    Doc_B
  • David J
    May 22, 2005 at 12:07 pm
    You might want to try capturing using Scenalyzer Live (www.scenalyzer.com). Try before buy with watermark, but it will allow you to test your capture system with non-Adobe software. If you still have problems, I would suspect your capture system/source material rather than the Premiere end.
