Activity Forums Adobe Premiere Pro Premeire OMF to mix in ProTools – Not Able to Mix MultiChannel WAV files
  • Premeire OMF to mix in ProTools – Not Able to Mix MultiChannel WAV files
    Posted by Josiah Spencer on November 3, 2010 at 9:18 pm
    Project: A Film
    Edited on: Premiere
    Audio: Multichannel WAV files recorded on set. Each WAV file per take has multiple channels for example: Channel 1:Boom mic | Channel 2: Lav on character A Channel 3: Lav on Character B etc.
    In Premiere Pro CS4 – I link these WAV files to the video and I can see the multiple tracks all different.
    I export an OMF to ProTools and it will not bring in the separate channels form the WAV file in order to mix individually.
    Any Ideas?
    Martin Casares replied 15 years, 5 months ago 2 Members · 1 Reply
  • Martin Casares
    April 6, 2011 at 5:50 pm
    Hello… I’m having this same problem, did you find any solution for this?
    I’ve tried exporting FCP XML and then processing a new OMF from FCP, but that way I end up with sync problems.
