Activity Forums Adobe Premiere Pro Prem CS5 – Cant capture HDV from my Canon XLH1s
  • Prem CS5 – Cant capture HDV from my Canon XLH1s
    Posted by Laura Petrella on August 4, 2010 at 9:26 pm
    Hello everone!
    I am having a hard time capturing a video that I shot in HiDef.
    I have Prem CS5. The capture window does not see the video, cannot record it, does not have TC running, yet it can start or stop the camera. Yesterday I thought I had succeded and instead I imported DV at 740 x 480 . Yet the sequence had the correct settings. I am really confused. This is my first major HD work on P CS5 and I hope someone can help me.
    Thank you!
    David Knarr replied 16 years, 1 month ago 5 Members · 8 Replies
  • 8 Replies
  • David Knarr
    August 5, 2010 at 1:34 am
    Hi Laura,
    It’s a common problem. Here is an article to show you how to fix it:
    https://www.studio1productions.com/Articles/Firewire-1.htm
    Dave – Studio 1 Productions
  • Ann Bens
    August 5, 2010 at 12:06 pm
    Try capturing with HDV Split. Is not as picky as Premiere.
    https://strony.aster.pl/paviko/hdvsplit.htm
    And it gives you preview which Premiere still cant do.
  • Jeff Pulera
    August 5, 2010 at 1:58 pm
    Hi Laura,
    Most HDV cameras by default from the factory are set to DOWNCONVERT HDV > DV on the 1394 output. That’s why you have timecode and deck control but no video, camera is sending out DV but Premiere is looking for HDV signal.
    With camera in VCR mode, go into menu settings and look for the “DV Convt”, “1394 Convt”, HDV > DV” or similar, I forget the wording Canon uses. Turn this OFF, and also, for “VCR”, you may have a choice of AUTO, HDV or DV, set this to HDV.
    Important: CLOSE Premiere. Turn the camera OFF. Now power up the camera again (already connected via 1394) so PC recognizes it as an HDV device rather than a DV device. Now you can start Premiere and should be able to capture HDV
    Jeff Pulera
    Safe Harbor Computers
  • Laura Petrella
    August 5, 2010 at 11:00 pm
    Thank you Dave.
    I have tried it but it did not work. Still no response from P CS5.
    Any other ideas would be welcomed. 🙂
  • Laura Petrella
    August 5, 2010 at 11:07 pm
    Hi Ann,
    I tried what you suggested. I don’t know if HDV split works with Windows 7. I also was not able to download some required drivers because the following link was not working. https://hdvforever.com/hdv/hdrhc1/freecapture/default.htm
    So unfortunately still no solution
    Do you have any other ideas?
    Thank you so much
    Laura
  • Laura Petrella
    August 5, 2010 at 11:09 pm
    Hi Jeff,
    thank you for your input. I checked the camera and it seems to have all the correct settings to playback HDv. But Premiere CS5 still does not recognized it.
    Any thoughts?
    Thank you for your help
    Laura
  • Jon Barrie
    August 6, 2010 at 1:03 am
    Can you confirm the FW cable works and the camera can be detected at all? You may have burnt out the FireWire connector on the camera by accident!
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • David Knarr
    August 6, 2010 at 2:47 am
    Laura, are you on a Dell computer? They are known for having problems with the built-in firwire ports and video capture.
    Either way, you might want to try a cheap firewire card from Best Buy, you can get them for $10 to $20. That has fixed the problem for me on a HP computer.
    There are several different Firewire chipsets that the various motherboard manufacturer’s use. Most of the time a Firewire card will have a different chipset than what is on the motherboard. Using the Firewire card will fix it 99% of the time.
