Activity Forums VEGAS Pro Preferred way to adjust audio levels (event or track or both)?
  • Preferred way to adjust audio levels (event or track or both)?
    Posted by Robert Maier on November 19, 2020 at 6:18 pm
    What is the best (primary) way to adjust audio levels in an audio track– use the track level with edit points, or the event level? I’d guess use track level, so you can make quick level changes. But sometimes it’s easier to slide the event level for a quick change on a short event. Or I guess both, but when I do that, I sometimes get confused which is active. Should I just always stick with the track level, so it’s consistent, and just forget the even level? This is for a 6 minute video with about 138 cuts (picture and sound total).
    Dave Turnidge replied 5 years, 9 months ago 2 Members · 1 Reply
  • Dave Turnidge
    November 25, 2020 at 6:26 pm
    It looks like you haven’t gotten a response… I use iZotope for initial audio modifications – and if I run into something after starting my video edit – I will often return to iZotope. Other than that I will use a volume envelope to make modifications that are more straight-forward…
