Activity Forums VEGAS Pro Preferred Monitor Color Management system
  • Preferred Monitor Color Management system
    Posted by Ralph Hajik on March 28, 2013 at 4:55 pm
    Hi Vegas Users,
    I know there’s many Monitor color calibration systems out there. I like to find out from Vegas users what they prefer, what’s easy to use without being a rocket scientist and what not to buy. My intentions are to calibrate my monitor for Photoshop and Sony Vegas Pro.
    Thanks for your input and expertise.
    Ralph Hajik
    Happy Travels
    https://www.LastingMemoriesR4ever.com
    John Rofrano replied 13 years, 5 months ago 3 Members · 2 Replies
  • Michael j Toffan
    March 28, 2013 at 11:10 pm
    Hi Ralph,
    I am using Spyder4 Elite by Datacolor and I am happy with the capability. Datacolor has several levels of product each with different levels of capability. More capability obviously also costs more. I have found it fairly easy to use and the results are consistent. One set can be used to calibrate all your monitors. After calibration, you can compare the results to RGB, ADOBE RGB, NTSC and full color gamut. The results of the calibration will be dependent on the quality and capability of each monitor. For instance some lower level laptops will not be able to resolve even the RGB color space and while some high end desktop monitors can resolve most of the ADOBE RGB color space. No matter what quality of monitor you have, or what calibration product you end up using, your product will be much improved and more consistent if you keep your monitor calibrated.
  • John Rofrano
    March 29, 2013 at 11:39 am
    [Michael Toffan] “I am using Spyder4 Elite by Datacolor and I am happy with the capability. “
    +1
    Same here but the older Spyder 3 Elite and very happy. Datacolor Spyder is a great calibration tool.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
