Activity Forums Adobe Premiere Pro Preferred image format to use in Premiere?
  • Preferred image format to use in Premiere?
    Posted by Beom Koh on December 14, 2010 at 3:41 am
    Hello. I am working on a project that require many subtitles. And I usually make subtitles in Photoshop with transparent background and save as .psd and load in the Premiere pro. However, it seems to me that this way really slows down the premiere a lot when 1) loading the project, 2) switching between different programs using ALT+Tab. So I figured .psd might be heavy to use and tried to use .png or .tiff but it still is really slow.
    I can not use the “Title” menu in Premiere because it limits what I can do with subtitle.
    What do you guys use to make subtitle?
    Thank you
    Jeff Brown replied 15 years, 8 months ago 2 Members · 1 Reply
  • Jeff Brown
    December 14, 2010 at 2:00 pm
    I also use Photoshop for titles. It sounds like you might be running low on memory.
    -Jeff
