Activity Forums Adobe After Effects Precomposing
  • Precomposing
    Posted by Pat Trimmer on December 30, 2014 at 2:52 am
    I’m fairly new. Nevertheless, I’ve never had trouble precomposing before. I:
    Make sure I have the arrow tool and that the caps lock is off
    Select the layers (Text, Adjustment, Text)
    Press Control Shift C…
    And nothing happens.
    Am I missing a step, or ????
    Thanks in advance for any help.
    Pat Trimmer replied 11 years, 8 months ago 2 Members · 4 Replies
  • John Cuevas
    December 30, 2014 at 12:50 pm
    What are you trying to precompose?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Pat Trimmer
    December 31, 2014 at 1:01 am
    I am trying to precompose 3 layers:
    The top layer is a Text layer.
    Under that is an Adjustment layer.
    Beneath that is another Text layer.
    (I have failed once–700 times.)
    Pat
  • John Cuevas
    January 1, 2015 at 2:39 pm
    Can you use the drop down under layers to pre-compose? Can you precomp, the layers individually?
    Thinkck.com
  • Pat Trimmer
    January 1, 2015 at 8:39 pm
    Thank you for your attention to my problem. I actually feel very foolish. I was trying to compose with shift-control-C. It’s working with now with shift-command-C.
    Again, my thanks,
    Pat
