Activity › Forums › Adobe After Effects › pre comps nesting problem
  • pre comps nesting problem
    Posted by Anita Sancha on October 21, 2008 at 7:05 pm
    Hi guys..
    I am animating a pipe with a nozzel on the end. This sequence is in a comp which is imported into the main comp. (all in same project, same presets) However the nozzel does not stay in the same position that it was in the pre comp. I can get around this by exporting and re importing. But now, this is happening again on another sequence. What might I be doing wrong? please. Any ideas.
    Anita
    David Bogie replied 17 years, 11 months ago 2 Members · 1 Reply
  • David Bogie
    October 21, 2008 at 9:43 pm
    Is there a 3D switch on someplace?
    There are only two explanations I can think of, one is a 3D switch that shoudln’t be on or you have simply moved the anchor point of the layer that represents the precomp.
    bogiesan
