Activity Forums Adobe After Effects Pre-Comps and Cameras
  • Pre-Comps and Cameras
    Posted by Durwood Hibbard on February 15, 2011 at 1:56 am
    Hello there,
    I am working on a Highlights video for a youth basketball league. I have a Basketball court and some banners that I have made along with 3 big screens that will be showing the footage. I want to move around the court and from one screen to another. Right now will the room only built the comp time line isn’t to bad to follow. However when I start bringing in my footage to place in the screens I am afraid it will get a little messy. I attempted to pre-comp the court and banners in one comp and then the screens and footage into another comp. My Problem I am having is controlling both comps with a camera when I put them into a main comp. is it possible to control both comps with one camera? or do I just need to make one big comp with many layers?
    Durwood Hibbard replied 15 years, 6 months ago 2 Members · 2 Replies
  • Michael Szalapski
    February 15, 2011 at 4:53 pm
    I have some comps where I have hundreds of layers. Sometimes the shy switch can be used to help clean things up.
    If you’d rather have a layer in one comp control a camera in another comp, you could link them with expressions.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Durwood Hibbard
    February 15, 2011 at 10:01 pm
    THAT’S IT DAVE….The Continuously Rasterize/Collapse Transformations switch was unavailable in the comps themselves. However when I clicked it on the pre-comps it set everything back to how it should be or how it should look. I moved the camera around and it worked great. Thank You
    Also thanks You to Michael, I seem to forget about the shy switch. I will be using that as the project continues.
